Yet ANOTHER tire pressure sensor question
Old Jul 14, 2004 | 07:56 PM
jw38's Avatar
jw38
St. Jude Donor '14,'18,'21
Default Yet ANOTHER tire pressure sensor question
Does anyone have pictures that outline the installation procedure for 04 tire pressure sensors? I want to see where the infamous O ring goes!!!
Old Jul 14, 2004 | 09:02 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
There are two types of sensors.
The older style 97-00 has a separate o-ring.
The newer style 01-04 has the o-ring integrated with the sensor.
So there is no way to install the o-ring in the wrong place.
But just for the record it goes between the sensor and the inside of the rim.
Old Jul 14, 2004 | 09:03 PM
KCvetteowner's Avatar
KCvetteowner
I have an '02 and didn't require the 0-rings. I believe (but I'm not certain) the O-rings were not used on '02 to current model Z06s.
Old Jul 15, 2004 | 01:44 AM
Shylor's Avatar
Shylor
The 01-04 did not have O-rings. It does have a rubber seal integrated in the unit. You also have to get the nut for each unit. http://www.etools.org/files/public/T...te_from_GM.pdf
Old Jul 15, 2004 | 08:42 AM
jw38's Avatar
jw38
This is why I love the Forum!!! Thanks everyone!!!
Old Jul 15, 2004 | 12:46 PM
CAPN17's Avatar
CAPN17
There is a rubber washer that can be changed if yours is chewed up. It goes on the valve stem inside the wheel, a good idea is to put a light coat of silcone grease on the washer to help it seal.
To Yet ANOTHER tire pressure sensor question
