Aluminum Flywheel installation question.
Or is there anything special when doing the install?
Can I just follow the manual for stock flywheel install for torque setting...?
Will it come with all needed parts for installation or can I just the stock bolts?
It can physically replace the stock part.
It can be tight on the crank so you may have to heat it a bit.
Yes
Stock bolts are OK & ARP’s are available (metric sizes)
Balance strategies
A stock flywheel & pressure plate is zero balanced as a set at the factory.
A Vette may have push-in balance weights in the flywheel that are used to fine tune the engine balance after assembly.
The safest way to replace the flywheel only is to take the old & new parts to a balancer and have your new combination match balanced to the old parts.
If you can’t do the above, zero balance the new combination of parts.
Good luck,
Steve
