Intake Manifold Repair
Old Jul 17, 2004 | 06:45 PM
2KREDVert's Avatar
2KREDVert
Default Intake Manifold Repair
I have a Z06 Intake Manifold with a loose brass vacuum fitting right behind the TB. I have the manifold off and stripped. There is a small crack on the interior of it just in front of the brass fitting. What is the right stuff to use to patch or repair it? I want to tighten up the fitting from the inside. Would plain old ABS glue work?
Old Jul 17, 2004 | 06:49 PM
LoneStarFRC's Avatar
LoneStarFRC
If it were me I would leaning more towards epoxy. Just be sure to really clean the area first. Maybe rough it up first with with a little sandpaper. HTH
Robert
Old Jul 17, 2004 | 09:27 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Robert
I would be thinking about JB Weld.
Old Jul 17, 2004 | 09:39 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
________________________________________ ____________________
JB Weld.......Great Stuff......Make sure the piece to be repaired is clean, and give the JB Weld 24 hours to harden. It's helped me out more than once.
Old Jul 17, 2004 | 10:35 PM
2KREDVert's Avatar
2KREDVert
Does anyone know what GM recommends? There must be a recommended material that is fully compatable with the original plastic. I doubt that JB Weld is chemically compatable. I'd like to use the right chemical composition to get a lasting repair.
Old Jul 19, 2004 | 08:34 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Mine cracked and we used a soldering iron and then a thin film of silicone.
Old Jul 20, 2004 | 02:40 PM
2KREDVert's Avatar
2KREDVert
A friend of mine has a plastic welder and often uses plain old ABS pipe as a welding material. He recently "welded" my grill back together on my GMC Motorhome. I have a feeling that basically our C5 intakes are actually a network of sewer pipes. Does anybody know what they are made out of for sure?
To Intake Manifold Repair
