Headlight Alignment: Anyone have a quick How To do on this?
Old Jul 18, 2004 | 09:22 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Default Headlight Alignment: Anyone have a quick How To do on this?
[B]I installed a pair of low beam Silverstars a few weeks back and must have knocked my alignment out. Can anyone post a quick How To on Headlight Allignment on a C5.
I searched this site high and low and found nothing.
Glenn
Old Jul 18, 2004 | 10:42 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Hmmm...I had the same issue kinda...the Silverstars may not have "seated" correctly..other than that it is damn hard to knock them out of alignment....and it is super easy to bend a tab ..I had to pull the whole damn thing out to fix the tab and remount the assembly
Old Jul 18, 2004 | 11:22 AM
MTV's Avatar
MTV
St. Jude Donor '03-'04-'05
Let us know if either of these help.
http://www.midstatedmc.com/tech/aim.htm
http://www.c5forum.com/diy/eurolights2.php
Best, mtv
Old Jul 18, 2004 | 11:38 AM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
When I installed my PIAA replacement lamps I could not get all three tabs in on the low beams. No matter what I tried they would not go in which resulted in the lamp being way out of alignment. I could reinstall my stock lamp on the first try and they went in perfectly. I actually had to take the lamp, remove the "O" ring and take a dremel to the surface of the base and sand off .006 of material. After that they went right in. I have never heard of anyone else haivg this issue.
Old Jul 18, 2004 | 11:47 AM
Glennm27's Avatar
Glennm27
I will first double check that the bulb is seated properly and then move on and use the 2 links above to help in alignment.
I appreciate the replies guys.
Old Jul 18, 2004 | 11:49 AM
Oldvetter's Avatar
Oldvetter
I had to adjust my headlights after putting in Silver Star Bulbs. I forget when the screws are (there are 2 on each headlight), but be careful as the gears are plastic and you can strip them.
To Headlight Alignment: Anyone have a quick How To do on this?
