Active Handling Problem
Old Jul 18, 2004 | 07:28 PM
Bob Bunting's Avatar
Bob Bunting
2nd Gear
Default Active Handling Problem
I have a 2003 50th Anniversary with 1300 miles which now displays a "Service Active Handling" light on the information center on the dash. Has anyone else experienced this problem? And if so, what is the usual solution? (I am taking the car in for service this week and was curious as to the potential fix).
Thanks,
Bob
Old Jul 19, 2004 | 11:36 AM
C5XTASY's Avatar
C5XTASY
Thanks,
Bob
It could be a steering sensor, wheel sensor, ABS pump, computer module, grounding problem, etc. If you are able, take your car into the dealer with the alarm message still active. Do not turn the motor off, and let the tech do his investigating with the alarm on. These are very difficult for technicians to zero in on. I've been fighting one for a couple of years now. May have finally been traced to a grounding issue. If it comes in again, the tech is going to replace rthe ABS pump. Good luck to you.
Ed
Old Jul 19, 2004 | 12:02 PM
Richin Chicago's Avatar
Richin Chicago
Thanks,
Bob
See what codes you have and post them:
http://www.stengel.net/diccodes.htm
Old Jul 19, 2004 | 05:48 PM
Bob Bunting
2nd Gear
Sorry, I don't know what the codes are, but the car is scheduled
for a service appointment tomorrow. I'll let you know how I make
Old Jul 19, 2004 | 05:52 PM
Bob Bunting
2nd Gear
Thanks so much for your reply. I don't know the codes, but
it is scheduled for service tomorrow. I'll update you on my
progress. I sure hope it's good.
Thanks, Bob
Old Jul 19, 2004 | 09:00 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
A lot of "GM Techs" guess at whats wrong and have been known to "EASTER EGG" their way through customer problems! If you have a warrenty you are back 3, 4 maybe 5 times to get the problem fixed. If it on your dime start shelling out $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$$$$$$$!!!
It to your advanyage to learn your car, know how to read the codes and know what each one means. That way you are less of a sheep when you walk into the pack of wolves. If they tell you "Sir your BCM needs replacement and you know the codes told you that the Right Bank O2 sensor was the issue you can toss that at them and watch them try to tap dance!!
Ed
I have been suffering with "GROUND" issues for a L O N G time with my 98 coupe! I am going to CUT off all of those ground wire termination blocks and use the good old fashion ground lug!
Bill C
Old Jul 20, 2004 | 01:35 AM
Bill Dearborn's Avatar
Bill Dearborn
Bill C,
You may need a new EBTCM. Depending on whether you have AH or just Traction Control. GM had to make a design change on the early TC EBTCMs due to intermittent traction control, ABS problems. Fixing the grounds did not cure the condition.
Bill
Old Jul 20, 2004 | 04:22 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill
My problems centered around the Throttle Actuator Control module. I had to get a "REVISED" module (same GM pooblems ) and that got most of the problems fixed. The other problem that I was having was when I turned the key to the RUN position, I do not get all of the functions that I normally get and I throw a bunch of codes. I dont hear the fuel pump run to charge up the fuel rail, yhe TC off light on the dash illuminates and the AC/heater fan will not come on. If I cycle the key a few times or leave it in the run position for a while it will return to normal but I have to clear the codes or it will be in the "REDUCED POWER MODE" It is weather dependant and messing with the grounds changes the faults!
I see GROUND surgery in the near future!
BC
Old Jul 20, 2004 | 05:59 PM
C5XTASY's Avatar
C5XTASY
BC
Just a note of caution on submitting for warranty work. If you're under the original warranty, probably no problem. However, I do not believe the GM extended warranty covers wiring issues, which could involve significant time in troubleshooting. If you're close to the factory warranty expiring, get it done right away.
Ed
Old Jul 21, 2004 | 01:26 PM
davyalabama's Avatar
davyalabama
Mine was a faulty connection to the 3rd light (idiot light) in back.
Old Jul 22, 2004 | 11:48 AM
Bob Bunting
2nd Gear
Default Active Handling Update
To Update You On My Problem---active Handling Warning---
The Code Came Up #1282. It Is My Understanding That It
Old Jul 22, 2004 | 11:51 AM
Bob Bunting
2nd Gear
To Update You On My Problem With Service Active Handling
Old Jul 22, 2004 | 11:55 AM
Bob Bunting
2nd Gear
TO UPDATE YOU ON THE SERVICE ACTIVE HANDLING PROBLEM,
THE CODE CAME UP #1282, WHICH I'M TOLD IS THE SOP SENSOR,
THE CAR THINKS THAT YOU ARE LOSING CONTROL OF CAR, SO
IT APPLIES THE BRAKES. THEY TELL ME THAT THEY HAVE NEVER
HAD TO ORDER THIS PART BEFORE, SO ISN'T IT MY LUCK!
HAS ANYONE ELSE HAVE A SIMILAR PROBLEM?
THANKS, BOB
Old Jul 22, 2004 | 05:24 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What is a SOP sensor??
BC
Old Sep 30, 2004 | 04:43 PM
roscoe118's Avatar
roscoe118
Ed
Does anyone know if a poor connection of the "smaller" ground cable, that comes off of the negative battery terminal, could cause damage to the PCM or AH control module?
I just dropped off my '02 at the dealers with the AH, ABS, TC error messages on the DIC (started on Tuesday morning). They (well the Service Advisor anyway) called and told me that the PCM was fried . I said WTF, I'll be right over. The only Code in the DIC was a TCS 1214 which is a solenoid failure. So I talk to the Service Director, and he shows me that the small ground cable from the negative battery cable is loose, and said that they measured 4.5 volts at the AH module which is in front of the engine. He never says anything about the PCM.
I thought the PCM was under the battery (or is that the BCM?) I guess they could share this same ground.
Anyway, I am kind of confused, and wondering what the "smaller" ground cable from the battery is used for.
They are going to fix it under warranty, but have to keep the car until early next week because they don't have the part (PCM or AH control module) and it is on back order It's going to be a long sleepless weekend
Old Sep 30, 2004 | 05:51 PM
Bill Dearborn
Why are they keeping the car? You drove it in with those problems and should be able to drive it until they get the parts.
Bill
Old Sep 30, 2004 | 05:55 PM
C5JONNY's Avatar
C5JONNY
I keep getting a 1281, just ignoring it for now, Car goes to active handling warming up a lot too now.
Old Sep 30, 2004 | 06:37 PM
roscoe118's Avatar
roscoe118
Bill
Well, they gave me some line about "anything further that might happen", not being covered under warrany if they turn it loose now.
To Active Handling Problem
