motor to rwhp
Contrary to popular belief, a fixed ratio like 12% or 18% doesn't really work, especially as the hp numbers get larger.
I think about 50 rwhp is a good rule of thumb for basic lost hp on most vettes, and then add another 5 rwhp lost for every 50 hp you add to the stock 350 flywheel hp.
Example 500rwhp Vette on the dyno, looses 50 + 5+5+5 = 65 total lost hp from engine to rear wheels. So the above Vette shows 435rwhp on the dyno.
These losses must increase the more and more as hp goes up because of rotational losses, and more friction in the driveline.
This is just my common sense view. By the way, if you go check out the Dynojet website, they tell you that you just can't reliably calculate flywheel hp starting from rwhp. I think we can however get a good approximation because of all the dyno data we have available on this forum.
Cheers,
Mark
