Help, car running like crap!
Old Jul 20, 2004 | 01:30 PM
Jake99's Avatar
Jake99
Default Help, car running like crap!
I ran the car empty during a DE. When I did that and put 3/4 tank of fuel in it, it still would not run, or even idle. I came home and replaced the fuel pump and it ran great for about three days, now it runs like crap, and barely idles. I checked for the A/C overflow into the computer, but no moisture there. I have Code P0300H, misfire code. Could my fuel filter be plugged up and cause this???? Out of ideas.
Thanks in advance!
Old Jul 20, 2004 | 05:34 PM
mdhmi's Avatar
mdhmi
P0300H is a 'Engine Misfire Detected' code. Have you checked your plugs and wires? The 300H errors has been reported a number of times following the install of LT headers. Is your car throwing any other codes?
Mark
Old Jul 20, 2004 | 07:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Carefully remove each wire and measure the resistance from end to end. Each wire should be within this range: 250 ohms to 750 ohms. and the insulation can NOT be burnt! If you have wires that measure in the thousands or megohm range, you have found your misfire problem!
BC
To Help, car running like crap!
