cant read odometer
Old Jul 20, 2004 | 10:58 PM
cosentino11's Avatar
cosentino11
Default cant read odometer
hey guys i need some help, I am looking at a 2000 coupe that my friend picked up from an auction its a salvaged title and everything works but we cant get the odometer to light up and none of the other info comes up, does anyone know what quick things I can check, to get it to work? Fuse, plugs etc?? T hank you for anything -Mark
Old Aug 9, 2004 | 08:34 PM
cosentino11
Ttt Has Anyone Heard Of The Little Odometer Display Failing To Light Up? Has It Ever Burned Out Etc?any Ideas????? Thx
Old Aug 9, 2004 | 09:17 PM
PaceThis's Avatar
PaceThis
Check to make sure that the dash lights are turned up (on dimmer switch). Also, have you tried cycling to find if any info shows on display?
If the car starts and the cluster works otherwise, and it's not the dimmer, you probably need a new cluster.
To cant read odometer
