Anyone that may know from experience what the difference is? I bought a stinger and was wondering if selling it and purchasing a trap is worth it?
From what I have heard, and seen in the pictures, the trap is a bottom breather and the filter goes all the way down to rest behind the front license plate cover...the Stinger as you can see is a "top breather" does not hang down as low. I just installed the Stinger yesterday myself.
maybe I'll see ya around I am in LZ not far from Cary
ohh and the Trap is supposed to be more of a cold air induction breathing more from the bottom..but they say they both flow the same amount of air 25% more than stock I think
What do you think of your stinger so far Ive only had mine a week or so and not sure if I physically feel any change in HP. I thought maybe it would whistle a little like some other intakes do but it seems to be super quiet.
Yeah I'm right down the road from you, do you have any other modifications to your ride? I'm looking to purchase a exhaust and was wondering if you have heard any on C5's?
Jason
Hey Jason, the only other performance mod I have so far is an SLP LoudMouth exhaust,, the other mods I have are just appearnce mods. I have heard several different exhaust on C5's from going to some vette shows lately....it really depends on what you are looking for. You really need to listen in person..the sound clips are not real accuate..trust me on this I learned the hard way (the SLP is the 3rd exhaust I've had on my vette
Send me an IM or e-mail and we can hook up if you want to stop by Lake Zurich you can listen to the SLP...there are also a few shows coming up , next week 1 in Libertyville and then Crystal Lake were you can here some vette exhaust.
I think it takes a 100 miles or so for your computer to adjust to the added air,,most of the time with just an air intake you are only going to feel a better throttle response and not to big of a gain in HP unless you start getting into head/cam/ headers packages or more...I'll have to wait a few weeks to see if the Stinger wakes up a little more.
If you want absolute maximum HP and torque with no concern for cost, the TRAP with tunnelport (cutout in the front facia) is the way to go. If you want the best bang for the buck, including cold air intake, check out my cold air mod in Halltech's website. That'll cost you a whopping $25 and will give you a 10HP gain when the engine bay temps get up over 110F.
From: GOCC - Rebels Without A Clue Santa Barbara, CA
To my knowledge hardware wise the only difference between the Stinger vs Trap is another upper air bridge section. They use the same bridge piece top and bottom and you just continue on from the MAF to the filter section via another stepped rubber coupling and two more clamps.
Dave,
I always read your posts on this subject and respect your experience and enginuity. This is the first time I see you acknowledge the higher HP for the TRAP (I have one). I went with it based on Andy's advice and my own research here on CF. Basically the advantages of the TRAP are: colder air and a straighter air flow to the MAF. Also no cutting of the radiator shroud for your upgrade to the STINGER.
I did not cut the license area (not the look I want and have the SS inserts there that I do like) but do have the fog shrouds removed ..... plenty of cooler air available for that big filter. I got a BIG SOTP boost from this mod and am very happy.
Please post your thoughts on my comments.
JV02C5
Disadvantage of the TRAP is it is harder to install (I had A&A Corvette do mine). They will also get to service the filter every 15,000 miles!
There's no doubt in my mind that you have a great setup.
The system you describe seems closer to the Stinger-R with my cold air mod than to the direct path of a Tunnel port/TRAP setup, although the location of your Warhead filter is a bit more ideal (further away from engine heat). They all provide cold air and it may be a tossup as to which system takes the least amount of time to install.
Certainly, if ease of installation among all of Halltech's intake system variations is of utmost importance, then the Stinger-R without the cold air mod is the way to go.
Dave
Thanks Dave
Hopefully we didn't confuse the original poster too much...
