Nick Williams 90mm Throttle Body
Old Jul 21, 2004 | 06:06 PM
bamcoc5's Avatar
bamcoc5
Default Nick Williams 90mm Throttle Body
Where can I purchase a Nick Williams 90mm Throttle body? Do I have to supply a core? My 408 stroker is finally finished and ready to go in. I understand this is the only 90mm throttle body with problemless tunability with the 90mm FAST intake.
Old Jul 21, 2004 | 06:15 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Old Jul 21, 2004 | 07:15 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Try PMing Nitro-C5...
Old Jul 21, 2004 | 07:24 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Contact any of the Tuners on this Board - they should have it or be able to get it.
joel
Old Jul 21, 2004 | 07:26 PM
bamcoc5's Avatar
bamcoc5
Old Jul 21, 2004 | 08:09 PM
professorhp's Avatar
professorhp
I believe LG Motorsports has them if im not mistaken. Call them 972-272-7753.
Matt
Old Jul 21, 2004 | 09:27 PM
pdd000's Avatar
pdd000
Matt
Old Jul 21, 2004 | 09:31 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default Nick Williams TB
DTE---
Old Jul 22, 2004 | 08:33 AM
professorhp
Originally Posted by pdd000
WTF is your problem arsehole?
Old Jul 22, 2004 | 10:10 AM
Robert@SpeedDemon's Avatar
Robert@SpeedDemon
joel
Ive got a few at the shop... 281 866 7000
Old Jul 22, 2004 | 10:43 AM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
We have the newly revised units in stock now. Give us a call if you need one right away and we do require your core as trade-in. (260)407-5455
Best Regards,
DTE
Old Jul 22, 2004 | 10:57 AM
R6_C5_CLS55's Avatar
R6_C5_CLS55
This is the first I have heard of this TB. Is it true that there are no tuning issues when using it with the 90mm FAST?
--Sean
Old Jul 22, 2004 | 11:48 AM
DTE Powertrain
Collections Hold
There will always be some PCM re-calibration required anytime you alter/increase the VE of an engine, its just this unit requires less time with it to dial it in compared to others on the market and it allows much more idle throttle control/quality when large duration camshafts are used.
Regards,
DTE
Old Jul 22, 2004 | 11:55 AM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Old Jul 22, 2004 | 12:03 PM
Nitro-C5's Avatar
Nitro-C5
Moderator
St. Jude 15 Year Donor
Cruise-In V Veteran
St. Jude Donor '08-'25
Originally Posted by NEPTUNEBILL
Call Nick ...he has even improved his TB in the last few days---got one sitting on the desk another on the car--
I was one of the first to Run Nicks TB. Had a little trouble at the begining with idling, but after Nick made some adjustments runs great now. BTW: Nick's a good guy as well
Rick
Old Jul 22, 2004 | 12:11 PM
mwittkopf's Avatar
mwittkopf
We just put one of his new revision throttle bodies on yesterday and it worked perfect. With the old one, I had to do a little tweaking on the tuning. With the new one, I actually put the idle and airflow tables back to stock and it worked absolutely flawlessly. Perfect idle. I was very pleased and would definitely recommend it even if you don't have any local tuning capabilities!
Mike
Old Jul 22, 2004 | 01:12 PM
Antvette's Avatar
Antvette
Veteran: Marine Corps
How much is the Nick Williams 90mm Throttle Body?
To Nick Williams 90mm Throttle Body
Old Jul 22, 2004 | 01:47 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Best Regards,
DTE
PLEASE elaborate. What did you do to revise it? I am VERY interested in it. ANd is this a revised Nick Williams 90mm TB you talk about?
How much? Do you require a core?
Old Jul 22, 2004 | 02:12 PM
DTE Powertrain
Collections Hold
The revision was in the machining processes at the manufacturer and as stated earlier, we do require your core.
The completed unit is $599 and we also transfer/re-index your original electronics and stepper motor to the new throttle body for you, so when you receive the completed unit, it's ready to bolt on your intake manifold.
One techinical note worth mentioning: This unit has no provision for engine coolant passages like the O.E. piece, (who really wants that anyway unless your driving your car in the winter....) so you have to bypass the O.E. throttle body coolant hoses.
Regards,
DTE
Old Jul 22, 2004 | 02:37 PM
pdd000's Avatar
pdd000
just ordered mine from DTE. cant wait. ps thanks for the pm neptunebill
