Rear differential additive
Old Jul 21, 2004 | 07:06 PM
1 BAD C5's Avatar
1 BAD C5
Default Rear differential additive
I had the rear diff. fixed for the second time today. This time they replace the plate hopefully will fix the leak for good. I asked if they added the positraction additive and he said that it did not call for it.
I was under the impression it needed to be in there. Is there a service bulletin somewhere or something I can tell this guy. Or do I not need to worry about it at all?
Old Jul 21, 2004 | 07:46 PM
FKING1's Avatar
FKING1
Additive definitely is needed. Some lubes come with it in them so maybe this is what they meant. Did not need to add it separately.
Fred K.
Old Jul 21, 2004 | 07:51 PM
leaftye's Avatar
leaftye
Do you get lots of tire skipping when doing tight figure 8's? If you're not, don't sweat it.
Old Jul 21, 2004 | 07:59 PM
cortex's Avatar
cortex
Just from what I recently researched it seems with Mobil 1 or GM fluid you definitely need it (4 oz. with drain & fill). With Amsoil and Red Line, only use after the fact if you have chatter.
Old Jul 21, 2004 | 11:26 PM
BHP's Avatar
BHP
Mobil-1 states that it will work with limited slip diffs. No additive needed.
Old Jul 21, 2004 | 11:54 PM
Bill Dearborn's Avatar
Bill Dearborn
The GM fluid is also a synthetic so it may not need the additive either.
Bill
Old Jul 22, 2004 | 05:32 PM
1 BAD C5's Avatar
1 BAD C5
They said they used a synthetic oil. Will it hurt anything if I add it in there anyway even though the oil is synthetic?
Old Jul 22, 2004 | 06:29 PM
IMQUIK's Avatar
IMQUIK
Only add more if it chatters....if it is quiet.. keep on driving. Too much is not good.
Old Jul 23, 2004 | 12:53 AM
mapman's Avatar
mapman
The Service Manual calls for the additive. Why would you not use a lubricant required by the manufacturer? (Especially when the additive is inexpensive.)
Old Jul 23, 2004 | 02:33 AM
leaftye's Avatar
leaftye
I wouldn't use it if the diff was already working properly.
Old Jul 23, 2004 | 11:10 AM
mapman's Avatar
mapman
Using the correct lubricants is how you KEEP it working properly. Properly maintain your car - Do the next guy who will own your car a favor.
To Rear differential additive
