Exhaust install Help!
Old Jul 23, 2004 | 11:32 AM
csexton's Avatar
csexton
Default Exhaust install Help!
I am going to install a set of Borla Stinger exhaust. The tech tips article says to cut the stock pipes 2 inches from the mufflers for removal. I was going to hold on to the stoke setup in case I wanted to return to original. I sure hate to cut these. Is there anyway to remove originals without cutting up the stocks?
Old Jul 23, 2004 | 11:37 AM
Mike Mercury's Avatar
Mike Mercury
you do NOT have to cut the originals. But to get them off in one piece; you either need a lift - or get the rear 30" off the ground.
Also, don't forget to drop down the rear SwayBar. You don't completely remove it... just undo the fassteners and let it swing down.
Old Jul 23, 2004 | 11:44 AM
csexton's Avatar
csexton
Thanks! I do have access to a lift. Should I use any type of sealant at the pipe joints?
Old Jul 23, 2004 | 01:41 PM
Patches's Avatar
Patches
Here's a good diy web site for the install.
http://www.97vette.com/howto/mufflers/index.html
Old Jul 23, 2004 | 02:26 PM
csexton's Avatar
csexton
Thanks-Great site!
To Exhaust install Help!
