Testing exhaust backpressure?
Old Jul 23, 2004 | 12:12 PM
blu00rdstr's Avatar
blu00rdstr
Default Testing exhaust backpressure?
I'm suspecting I have melted cats, but how do you test for that?
I have stock exhaust, if I drop the mid-pipe for a test drive I lose the O2 sensors. Any other way to test?
Old Jul 23, 2004 | 12:32 PM
Dope's Avatar
Dope
Resident moron
I don't know of any way to test, but dropping the mid pipe won't hurt. Unplug the rear O2s, it will set a code but it won't hurt anything. I had no rear O2s on my old car for a few weeks before I programmed them out. Car was just a little bit sluggish from the code.
Dope
Old Jul 23, 2004 | 01:17 PM
myblackC5's Avatar
myblackC5
Default melted cats
undefinedyou can drill a small hole in the pipe in front of each cat. test them with the engine running. or a vacuum gage to the engine while running. if theres any exhaust back pressure, the gage will go down slowly. if the cats melt, it's a good chance the mufflers melted also. you can take the mufflers loose and see if it runs any different. the computer should tell you if theres a problem with cats
Old Jul 25, 2004 | 07:06 PM
blu00rdstr's Avatar
blu00rdstr
Good suggestion. I drilled and tapped the pipes right before the cats, ran copper tubing into the engine compartment and plugged to my boost gauge. Got 15psi on WOT.
Old Jul 25, 2004 | 07:50 PM
nuke61's Avatar
nuke61
15 PSI? Backpressure should be in the inches range, not pounds, and certainly not as high as 15 pounds !!!
Old Jul 25, 2004 | 07:59 PM
HalfMoon's Avatar
HalfMoon
Your blower and the string of 100 degree days we've had have done you in. I'll be down in a bit to trade you my stock exhaust for your blower, if you like you can start the removal and I'll be there in 30 minutes..
Old Jul 25, 2004 | 10:00 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Plugged cats can normally be seen with a vaccum gauge. At higher sustained RPM your vaccum will drop off due to the lack of flow in the exhaust system.
Old Jul 26, 2004 | 12:33 AM
blu00rdstr's Avatar
blu00rdstr
That's weird, I thought the lack of vacuum was due to the D1SC.
Tony, very funny!!
Old Jul 26, 2004 | 04:35 PM
SNW Vette's Avatar
SNW Vette
Default Exhaust Backpressure
Hi,
My 2002 C5 read 5psi @ full throttle & 6000rpm in front of the pre-cats when stock.
Good luck,
Steve
To Testing exhaust backpressure?
