OK, fellas. It seems like I'm having my first problem with my car. I bought this car this past December with 49K miles on it. It's got about 54K miles and it's a 99 Vert. It's about 88 degrees in Houston now, kind of hot, and I just went out for a drive around the city. No highway driving, but just a few minutes into the drive, I notice that the air conditioning is not blowing cold. I look at the temp guage and it read about 230. I drove home and the temps got to 239 and I shut it off. All this in about a 15 minute drive. I suppose that it's a engine cooling problem with the radiator being right next to the air condensor. Any ideas? I hope that this isn't going to cost an arm and a leg.
First thing is to trash the thermstat and put in a 160 degree thermostat.
Next, take it for the same ride and post what happens.
I await the results.
Good luck.
with both symptoms.. hot coolant and no too cold ac... IT sounds like the radiaTOR AND CONDENSOR fins are dirty clogged etc.. I have a 99 and about the same milage...I get about a cup of dirt, debris, sand bug guts leave particles pollen etc from this area...
you may have sucked up a plastic bag... I flush my radiator fins a nd condensor with water and comporessed air once a year in the spring...
Something else I noticed on my '04 when it was running a little hot - the foam that is supposed to seal the radiator to the shroud was coming off so the air was flowing AROUND the radiator instead of through it.
I fixed it with some thicker weatherstripping and now the car runs ~10 degrees cooler.
Just a suggestion - yours is probably just dirty/clogged.
1. Check for a plastic bag that is impeding the flow of air to the radiator fins.
2. If that's not the cause, I suspect that you have a stuck thermostat.
I just drove back from work and the temp seems to be stabilizing at 190-200. Yesterday, I did drive over a plastic bag and I didn't see it come back out. When I get a chance tomm, I'll try to get under the car and take a look. The good thing is that I live 4 minutes away from work. Thanks for the heads up. The car will go in for a full cooling system evaluation at Corvettes of Houston. These guys have done right by me in the past.
Good luck.
If there is no mechanical problem get a real radiator.Ya can leave the t-stat alone unless it's stuck. 160 is too cool
There is probably a misconception out there that needs a bit of clarification.
A 160 degree thermostat DOES NOT run at 160 degrees.
Mine runs at 176 on the highway on the hottest days and gets to 195 in heavy traffic. Never runs at 160 degrees.
Just wanted to vent, since a lot of people think that a 160 runs too cold. 175-195 is perfect and thats what you get with a 160.
I have a 170 T-Stat and the Vette runs at 187 driving and 203 at lights with the A/C on. One time it did get hotter than those temps and found a platic lawn bag and a bunch of leaves stuck up in the radiator. I might put a bottom screen on next
I just went through that whole senario. Finally took it to the dealer. It ended up being 1) new radiator installed, 2) new thermostat installed, 3) new A/C module installed. I have about 60k on my 2000 vert, basically stock but for a VaraRam. Went from 230 - 240 with ANY driving to hard to get over 190 on a hot day with ANY kind of driving. About 1000.00; fortuantely under warranty.
Programed into the pcm are fan settings to turn on the high speed coolant fan at 235 F... these temps are designed into the cooling sytem... if your car runs no hotter than 190... your fooling yourself or there is something wrong with your car...
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
This is right from the tech manual.
Well, I don't hear my fans running all the time. At highways speeds whether I'm pushing it or not it runs right at 189. Sitting in traffic on a hot day it will run to 212 momentarily but come right back down as soon as I get moving. The radiator was switched out because of a stripped drain plug (or so I was told). They still found high temps with the new radiator and switched out the thermostat. That brought the temp down. The external temp sensor in the radiator shroud was malfunctioning so it was replaced; also to no effect. They then found a bad board in the AC control module and replaced that. 1000 bucks on warranty gave me some new parts and fixed a few problems; the heat problem probably could have been fixed with just the thermostat.
I have a 160 T-Stat and my car will run 220 to 230 with the AC on,on a hot day of 95 to 104. When it gets to 230 I turn the AC off and it cools back down to 190. A 160 T-Stat will open to let the water flow sooner but it won't make the car run any cooler. You should be able to hear the fans when they both come on. It's normal for this car to run that hot. Freeway it runs 185 to 190 with the AC on.
Now that your car is "fixed" I shall repeat myself. Junk the stock thermostat, put in a 160-180, have the fan temps recalibrated (I did it with Hypertech) and be happy. (Last time before the "I told you so". )
Hey Guys, remember these cars have all aluminum engines. Aluminum has a higher coeffecient of heat transfer and expansion than cast iron. We are all to quick to remember the old days when at 220-230F you were steaming. Plus, your running almost 7 qts. of synthetic oil which also works as a cooling agent. Maybe GM should leave the numbers off the Temp guage.
