Coil-over conversion question
What are the major advantages of a coil-over suspension vs. the single cross mounted spring?
Any disadvantages?
Also, with the conversion kits out there - are there places to mount them to the frame or is welding/fab required?
Many thanks!
The real advantage conserns two things..first, you can change springs (for different spring rates) very easily and you can fairly easily adjust ride height on the fly - affecting (for good or bad) the geometry of the alignment.
As one who drives a coil over C5, it's very dependable on the track, and handles wonderfully. On the street, the telegraphing of road noise is well above the stock transversly mounted Corvette spring.
Cire
Any disadvantages?
Many thanks!
almost 60k mi, no issues
Here is their product sheet for the C5 Coil over suspension, I hope this helps
The adjustability sounds great - but intimidating.
Is the adjustability just FINE TUNING or is it something you could really dork up if you don't know (read - will I dork it up
)?Thanks again!
I don't know how the spring rates of the leaf springs change with compression, but with coils there are two options:
- constant (just the regular spring)
- progressive (spring rate increases with compression)
Progressive spring rates allow a softer sprung ride for most situations, while giving increased spring rates before the suspension bottoms out. I haven't experimented with progressive springs yet.
Cire
I have replaced the rubber with mono ball joints, but I am very happy with the ride.
The handling is excellent, which may also be attributed to the Penske shocks.
If you are not interested in playing around with the settings, and don't want to get adjustable shocks, you may be better off with leaf springs. Many users report excellent results with leaf springs in the roadracing section.
Till
Thank you.
I have their Coilover setup on my 93 SuperNatural with no issues
It was not yet installed on the Callaway Z06 I drove last month, It was used on the Callaway C12's with a similar design - VERY nice piece for sure
Till
