can't open trunk 2000 coupe
Old Jul 24, 2004 | 11:13 AM
cannonballred's Avatar
cannonballred
4th Gear
Default can't open trunk 2000 coupe
Purchased my first Corvette 6 months ago. Recently had GM dealer service clear blocked A/C drain which was leaking water on passenger side floor. Since then, I cannot open trunk with either remote or dash button. All other electronics seem fine. Dealer says needs new Body Control Module (expensive). Car has 17K miles. Any suggestions as to another solution?
Old Jul 24, 2004 | 12:18 PM
mdhmi's Avatar
mdhmi
Don't use the trunk? There really isn't much storage room in there anyway.
Good luck,
Mark
Old Jul 24, 2004 | 12:49 PM
2ndVette's Avatar
2ndVette
there is a manual method for opening the trunk. Look for a small (silver) cable about 16 inches below the interior trunk latch. Pull the cable and the trunk will open. A similar cable for the manual operation of the gas cap is found in the trunk interior just above the rear driver's wheel well.
Old Jul 24, 2004 | 01:32 PM
CAPN17's Avatar
CAPN17
I find it hard to believe that the trunk latch failing would be the only symptom of a bad BCM. Start tracking the wires and check the fuses, the worst would be a solonoid at the trunk latch, easiest a fuse.
Old Jul 24, 2004 | 07:10 PM
cannonballred
4th Gear
thanks.
Old Jul 24, 2004 | 07:13 PM
cannonballred
4th Gear
thanks..
Old Jul 24, 2004 | 07:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I had a very strange Column Lock bypass issue that was BCM related! This problem was on my NEW BCM and boy was I mad!! :mad On a hunch, I disconnected the battery, let it sit disconnected for a few minutes and the problem is GONE! Give that a try!
You can remove your BCM and see if the pins on the connectors are corroded! If they are corroded, clean them and see if that fixes the problem. I got brave and opened up the old BCM. Wow, its nothing special! I found some corrosion deposits on the board that cleaned up real easy with a nylon tooth brush!
If you are doing this on your BCM, be careful, it is (ESD) Electro Static Discharge sensitave!! If the board is corroded, clean it off and reinstall it!
Old Jul 30, 2004 | 09:04 AM
cannonballred
4th Gear
Bill, thanks for the advice, sorry for the delay, was away, will try these tips out and let you know.
To can't open trunk 2000 coupe
