HUD question
Old Jul 25, 2004 | 12:00 AM
VetteDawg's Avatar
VetteDawg
Default HUD question
To retrofit a HUD in a car not equipped, do you absolutely need a new cluster?
Mine's a 2000 with no HUD and no controls for it on the left of the cluster.
Old Jul 25, 2004 | 03:38 AM
Antvette's Avatar
Antvette
Veteran: Marine Corps
I remember hearing this somewhere, but I think you only need the HUD itself. There is already a connector there for it to hook up into. I found that out when I was looking at buying a 98 vette. Hope this helps.
Old Jul 25, 2004 | 07:09 AM
Miaugi's Avatar
Miaugi
You do not need a new cluster, apparently about halfway through the '99's all the clusters are HUD equipped. You do need the switch, the famous 11 pin connector, the projector & the bezel, everything except the 11 pin connector can be ordered from GM, the 11 pin connector can be found, but not from GM.
Old Jul 25, 2004 | 08:59 AM
98silverC5's Avatar
98silverC5
Hi Steve
Old Jul 25, 2004 | 10:45 AM
VetteDawg's Avatar
VetteDawg
I'm assuming that the 'switch' is what I called 'the controls' ??
...and I assume the bland piece that I have pops out and the switch/controls just pop in ??
Thanks for the help.
Nevermind !!
Found the answer(s) to my questions here
Last edited by VetteDawg; Jul 25, 2004 at 05:19 PM. Reason: found answer to my own question
To HUD question
