Gasoline leak help!
Old Jul 25, 2004 | 11:59 AM
MagRed01Atty's Avatar
MagRed01Atty
Default Gasoline leak help!
I have a 2001 C-5 and every once in a while I notice the smell of gas after i fill er up. I always figure it's overfilled and sure enough after i driver her a bit it goes away. Problem has gotten worse. I filled it up friday night because it was really low and it took 16.4 gallons, I thought it only had a 15 gal tank? I did not drive it again and noticed 2 days later there was a strong smell of gas in my garage and when I pulled the vette out, a puddle of gas on the floor.When I say puddle I mean about 2 cups. I parked in the driveway and cleaned up the mess and no more leak as far as I can tell. It has smelled gas before but this is the first time for a leak. I need to take it to the dealer but do not want to leave it overnight for ""Insprection and joy riding"" please give me some thoughts so I can be armed with some knowledge. veery dangerous problem. Thanks, Dave
Old Jul 25, 2004 | 12:49 PM
IMQUIK's Avatar
IMQUIK
Don't top it off....when it clicks off...your done.
If I top it off, mine will smell too.
Old Jul 25, 2004 | 02:32 PM
MagRed01Atty
I don't top off, I just let the handle click. I think maybe that still fills it too full. Why would the leak on the floor be located near the rear end section? Is there an overflow port nearby? Thanks
Old Jul 25, 2004 | 03:08 PM
quimbo's Avatar
quimbo
Sounds like the gas filter may be leaking I would check that out
QUIMBO SEEYAAAH
Old Jul 25, 2004 | 08:09 PM
MagRed01Atty
Thanks Guimbo
Where is the fuel filter and where located? hard to replace?
Old Jul 25, 2004 | 08:36 PM
ooh yeah's Avatar
ooh yeah
I had the same problem, it was the pass side gas tank. There is a gasket that only leaked when the tank was completly full. I also own a Mag 01. It was repaired under warranty, they replaced the whole tank.
To Gasoline leak help!
