IAT sensor
Old Jul 26, 2004 | 01:58 AM
donnyonee's Avatar
donnyonee
Default IAT sensor
iat sensor
has anybody tried 1 of the iat mods? its a resistor that goes in the plug, if there is 1, that fools the computer to think there is cold air all the time. i was going to put 1 on my 944 / LT1 i had but sold the car and now im into this c5. the 944 was awfully fast and would do circles around a stock c5, if your down towards westminister in so cal watch for a stone gray 944 and give him a try. thats porsches color for pewter. but if you look on the LT1/LT4 boards there is a iat sensor mod. anyone?
Old Jul 26, 2004 | 02:02 AM
donnyonee's Avatar
donnyonee
ttt
Old Jul 26, 2004 | 09:06 AM
6Speeder's Avatar
6Speeder
Lemme give ya two answers, you pick: 1. It's a cheap mod, go ahead and try it. You'll probably get what you paid for, but it might work.
2. Don't do it, the PCM uses the IAT reading to set spark advance and A/F ratio, do you want it to set these critical items based on false data?Better to go ahead and get it tuned correctly with LS1-edit on a dyno. The PCM works pretty well if it is given good data, don't try and fool it. FWIW I ran a recalibibrated IAT on a stock-ish motor, it still varied with temp, just read a little lower than reality. Worked OK, gave a couple more degrees of tming, buty when I modded the motor I went back to stock IAT and tuned the PCM correctly.
Old Jul 26, 2004 | 09:13 AM
donnyonee's Avatar
donnyonee
but has it been tried?
Old Jul 26, 2004 | 09:26 AM
nuke61's Avatar
nuke61
See the post by 6Speeder... "FWIW I ran a recalibibrated IAT on a stock-ish motor, it still varied with temp, just read a little lower than reality. Worked OK, gave a couple more degrees of tming"
Old Jul 30, 2004 | 11:50 PM
leaftye's Avatar
leaftye
No offense, but it sounds like a dumb mod you'll regret. I descreened my MAF, and I regretted it. I'm sure it may have given me a little extra power, but it also gave me tip-in KR that I could not tune out with HP Tuners. I an unmodified MAF, and the tip-in KR went away. I'm never screwing with a sensor again!
944's handle extremely well, but a bit underpowered. Are you saying you have a LT1 in a 944?? That would take care of the power issue, but it'd kill the handling in a car that was arguably the best handling car ever.
Old Jul 30, 2004 | 11:53 PM
donnyonee's Avatar
donnyonee
car only gained 130 lbs, removed the a/c and pwr steering and back at 50/50, still the best. will just plain kick *** on a stock c5.
Old Jul 31, 2004 | 09:14 AM
leaftye's Avatar
leaftye
How hard is that conversion? What kind of 944 do you need? N/A or turbo motor, N/A or turbo suspension? One of my buddies had a 944, and it was pretty sweet, but when his tranny let go, he had to look pretty hard to find a replacement tranny. We ended up driving from Alabama to Arkansas to pick one up.
Old Jul 31, 2004 | 06:01 PM
donnyonee's Avatar
donnyonee
i started with the na, but upgraded everything past the turbo model, trans axle was a turbo with a torsion diff, check renegade hybrids site. mine is in there as don from la habra.
To IAT sensor
