Does anyone know if you add an LS6 intake manifold to a 98 LS1 motor, will this put the car in a group 3 classification at the NCCC sponsored race events.
If this modification classifies the car as a group 3, is a roll bar required in the car.
I want to install an intake, heads and cam but do not want to install a rollbar in the car.
I don't know why an ls6 intake would make a difference if you still have less hp then the z06.
Please help before I go ahead with my mods.
You should contact Tim Bailey, NCC RCD for the West Region. Use this link to their website and you will see Tim's contact numbers on the RCD page at the bottom. I'm sure he can answer all your questions.
Unfortunately that modification will place you in a Group III classification. The NCCC rule book states that Group I is completely stock for the fuel delivery system - includes manifold. Group II you can update or backdate parts within class. The LS6 manifold is from a ZO6 which is a Class J your LS1 is a class H so the swap would not be allowed even in Group II, that leaves only III. Group III requires substantial safety equipment IE: roll cage, fire extinguisher system, driver fire suit, etc.
I dont think there is a group II J. Z06's in group II run IIH. You can add it and run in group IIH without a problem. Being in group II you will need a fire extinguisher. As far as the heads and cam, your out of luck. Heads can be port matched but the cam has to be stock for lift and duration. Good luck.
LS6 intakes were put on LS1 motors in 2002 and later from the factory, so I think if you add the LS6 intake to your car you would be in group 2H. As others have said, in Group 2, you just need a fire extinquisher.
Just a couple of clarifications, in Group 3, you need a 4 point roll bar as minimum, not a full cage. You also only need to wear a fire suit for high speed events. A fire suit is not required for low speed events which most autocrosses are classified as.
This seems like a quirk in the system. A bone-stock 2000 LS1 (345HP) next to a bone-stock 2002 LS1 (350HP) already has the difference between and LS1 intake manifold and an LS6 manifold. If the 2000 puts on the same manifold as the 2002 - he gets bumped all the way into Group III which requires all the safety equipment while the 2002 runs stock? That doesn't seem equitable. The only difference is who put the manifold on the car - the owner or GM. The LS6 intake manifold is not just from a Z06 - it was put on LS1s by GM in late 01 on.
If this is correct, it knocks me completely out of even considering NCCC autocross as I'm not interested in putting a roll cage in my car. Technically, my car would be bumped up a class by the SCCA not due to the manifold - but due to the rear sway bar replacement.
If this does bump you to class III a cage is NOT required it is reccommended according to the 04-07 rules. I have been researching this to see where the III/RP line is. If you jump to RP you are required to have a cage. Wolfe Racing makes a nice cage that is allowed and it is bolt in, the price is under a grand also.
Can you do anything to your heads and or cam and stay in group II?
Heads can be port matched and polished up to 1/4 inch. Valve springs can be changed for reliability. Cam has to be stock for lift and duration. There is nothing specified for LSA. Mine is a Z06 cam on a 112 LSA. Balancing and blueprinting are aloud. You can have aftermarket tuning, but no add on controlers. Any harmonic balancer. Bore can be up to .07" over stroke can only be stock.
