Being the (relatively) poor owner of a '98 A4... and not wishing to invest in (or risk the early model year hassles of) a CLB for permanent use when a workable recall fix is on the way... I keep thinking that there must be a cheaper, temporary do-it-yourself fix.
One member posted about using a $6 latching relay to simulate the column lock motor and provide the necessary feedback signal to the BCM. How hard can this be? The wiring diagram and basic logic are right here: http://tinyurl.com/6x7nc The C207 connector only has four leads... how difficult can it be to temporarily wire in an appropriate relay?
Yet another person said they they used a column lock motor removed from another C5... plugging it in and taping it off under the dash in a place where it could do no harm. Sounds like it could work if the feedback switch is, indeed, self contained.
Has anyone else come up with any other do-it-yourself fix? Are there any pitfalls I am not seeing here?
Monk
It's not difficult. Kind of like the $25 CAGS eliminator (it's a single resistor that anyone can buy at Radio Shack for a buck.) Knowledge is power (and in this case, money.) I've contemplated building these myself; at 20 bucks a pop I can still make a profit. The only reason I haven't done this yet is it will stab certain folks in the back (like JimX), folks that have contributed a great deal to the CF community. They are only making $$ on a few items, this being one of them..
It's not difficult. I've been contemplating building these myself; at 20 bucks a pop I can still make a profit. The only reason I haven't done this yet is it will stab certain folks in the back (like JimX), folks that have contributed a great deal to the CF community. They are only making $$ on a few items, this being one of them..
That part of the equation I understand perfectly. Vendors have overhead, advertising, employees and myriad other expenses. And they are providing an important service to those without the time or knowledge to investigate, build and test a home-made device. I would not try to undercut them.
On the other hand, I see nothing unfair or immoral with me making one for myself... or in helping out another poor do-it-yourselfer with information. I believe that's done here all the time!
Monk
Try getting a CLB from Zip--it works fine on my '98 A4 (built in June). I thought about growing my own as well, but took the chance and am glad I did.
Monk
Send me an email if you want the low-down, and I'll reply.
Yeah, I'd probably spend the money and take a chance that I was one of the very lucky '98 owners for whom the CLB works... although I have never been lucky like that before! But I'm also one of those folks who is still willing to let GM clean up their own mess... the new recall fix should be perfect for me since I have an A4. I am mostly just looking for a cheap way to get through this summer without a stranding.
Monk
You can always save a few bucks buy having one of your friends, read a manual, then they could perform brain surgery on you if you needed it...
Well, I've been reading the posts about the column lock problem for some time now and feeling real smug about how mine hasn't been any problem. Ha, shoulda knocked on wood. Backing out of driveway last weekend. Started it up, put it in reverse, engine dies, COLUMN HAD LOCKED!!! Shut off key and rocked steering wheel left-right then turned key. Column unlocked and everything was fine. Next immediate step, go directly to dealer with copy of "Electronic Column Lock System Recall" memo (courtesy of member "C5tech" elsewhere on this forum). I have been reading about a shortage of parts for this recall so I am expecting a big runaround on "when" for the fix. Dealer looks at my copy of the recall, checks my VIN # in database, and says "No problem", bring it in next tuesday. It looks like "the squeaky wheel gets the grease" is really true. I didn't even get to the point of mentioning about my lock-up. By the way, mine is a '98 A4, so take yours in and get it corrected for good (IF yours is an AUTOMATIC).
It's just a solenoid. Unplug the connector to it, measure the resistance. Then buy the right wattage resistor.
I think that's all there's to it.
One day when my lazy azz gets stuck somewhere, i'll do the same
Sorry, a bit more complicated than that (but certainly not brain-surgery complicated!)
Monk-
Don't think the recall will solve your problem. As I understand it, they will remove the lock plate and reprogram the PCM, but if the column lock fails it will still immoblize the car by shutting off the fuel but your wheel will still turn. Lots of help GM is! I'll keep my CLB. Jeff
