Im getting code P0352 Ignition Control #2 Circuit What does this mean?
Old Jul 27, 2004 | 10:12 AM
martin97c5's Avatar
martin97c5
Default Im getting code P0352 Ignition Control #2 Circuit What does this mean?
My check engine light keeps comming up, even if I clear the codes. Ever since I took off my old ignition wires and put these new ones on I have been getting code 0352, which is the ignition control circuit #2. Did I damage something where the ignition wire connects? My car seems to run fine? Is the ignition control circuit those 8 objects on top of the motor that the ignition wires plug into. (obviously im not so technically inclined )
Thanks for any input
Old Jul 27, 2004 | 11:43 AM
dpd's Avatar
dpd
ok,you are having issues on cylinder #2[right bank,first cylinder].the coils are mounted to the valve cover.make sure the plug on the front coil is secure.this fault sets if the pcm sees the control circuit grounded/opened or shorted to voltage for less than a second.if this started after changing plug wires,if you took the plastic valve cover trims off,maybe when you went to put them back on you grabbed the ignition coil harness and it pinched the harness to the coil rail.
Old Jul 27, 2004 | 02:15 PM
martin97c5's Avatar
martin97c5
Thanks dpd, I will check out the car when I get home from work today. Any other ideas anyone?
Old Jul 28, 2004 | 10:12 AM
martin97c5's Avatar
martin97c5
well it seemed like all the wires are ok. any other ideas? Maybe I should try replacing one of those ignition circuit moduels with one from another cylinder (just swap them) and see if the code goes away from #2 and goes to the one I swapped it with? Then I would know that its the ignition control circuit. WHat do you guys think?
Old Jul 28, 2004 | 05:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Give it a try!! It sure will not hurt anything!! Let us know how you make out!
BC
To Im getting code P0352 Ignition Control #2 Circuit What does this mean?
