Transgo Shift Kit Owners- Need your input
Old Jul 27, 2004 | 09:28 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default Transgo Shift Kit Owners- Need your input
For those of you running this kit, did you go with the stock feedhole sizes, or did you drill them a bit bigger for firmer line pressure? If you did go bigger, what were you numbers for 2nd, 3rd, and 4th gear?
Old Jul 28, 2004 | 08:23 AM
ArmyVette's Avatar
ArmyVette
I'd like to know this myself. Transgo tech support has no opinion on this question (I asked them).
Old Jul 28, 2004 | 11:42 AM
BHP's Avatar
BHP
My car is a 2004, stock converter. If using high stall, A and E need to be larger (about .150). Also the separator plate gasket holes need to enlarged when going over .125, A and E.
Here are my sizes as discussed with a Transgo tech.
A= .125
B= .093
E= .125
1 washer in the 1-2 acc.
These calibrations have been tested for six months and work fine.
To Transgo Shift Kit Owners- Need your input
