help...headlight install
Old Jul 28, 2004 | 04:12 AM
Izover4u's Avatar
Izover4u
Default help...headlight install
Well I upgraded my bulbs to HIDs... I took the old bulbs out and I cant seem to get the bew bulbs to to fit perfectly yes they are 9006 bulbs
... I got one side in to click into place but the other i am having the hardest time I think I many have bent the bracket or something... I dunno... I plan on taking apart the headlight so I can either fix what i bent or broke... any help would be great
Old Jul 28, 2004 | 10:48 AM
Miaugi's Avatar
Miaugi
I changed both my low & high beam bulbs, the high are fairly easy after you remove the bezel, but the low's are a bear! That is unless you have hands the size of a 5 year old with the strength of a 21 year old body builder.
To make my life easier I removed the top covers and then removed the 2 pins (bolts actually as I recall) that hinge the whole assembly, place a big towel in front of the headlight and then flip the whole assembly out (it will still be attached to the car), this makes it a breeze to get to the bulbs, well worth the few minutes it takes to remove the hinge. Good luck!
Old Jul 28, 2004 | 10:56 AM
jfrc's Avatar
jfrc
Originally Posted by Miaugi
.....That is unless you have hands the size of a 5 year old with the strength of a 21 year old body builder.
HaHa great description there
Old Jul 29, 2004 | 01:54 AM
Izover4u's Avatar
Izover4u
Thanks... Im going to give that a try tomarrow
To help...headlight install
