Driving home after a good canyon run in my 03 C5 I/C Magnuson s/c the Check engine fluids light came on. I pulled over right away and check the fluids and all was good I did notice on the driver side that there was some leakage that was sprayed all over the rear right side under the car but it was not a lot.
I have read that this is a common problem with the diff weeping out diff fluid under hard track or windy road driving but I have not read about the check engine light coming on as well. Any feed back would be great. I am going to try to get the error code off the car tonight. I printed out the how to and codes.
