Pulling the motor from top or bottom
Old Jul 30, 2004 | 08:49 AM
James G's Avatar
James G
Default Pulling the motor from top or bottom
I'm just curios, when pulling the motor, what is the popular method.
Iv'e heard pulling it out the top of the engine bay is a HUGE PITA vs.
dropping the entire drive train from the bottom.
Any commentary on your experience would be welcome.
Tanx,
JG
Old Jul 30, 2004 | 10:54 AM
kromberg's Avatar
kromberg
I pulled mine from the top. This is because I do not have a lift at home. It was actually pretty easy. The only hard part was removing the hood which required the help of my wife.
Keith
Old Jul 30, 2004 | 12:37 PM
blackbelt's Avatar
blackbelt
Keith
i second that and will add a little moving the engine foward off the torque tube is kinda a pita but I did the whole motor pull by myself minus help with hood in about 5 and a half hours. That wa my second time first took about 2 hours longer.
Old Jul 30, 2004 | 03:25 PM
jpas's Avatar
jpas
If you can get your car higher than 32" you can take out from the bottom, however you will need some kind of a craddle to lower the engine and wheel it out. I used a tranny jack, worked great.
Old Jul 30, 2004 | 04:42 PM
kromberg's Avatar
kromberg
Originally Posted by jpas
If you can get your car higher than 32" you can take out from the bottom,...
Wow, 32" is pretty darn high. What type of jack stand did you use?
Keith
Old Jul 30, 2004 | 04:58 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
If you have a lift then take it out from the bottom but if your working in your garage with no lift then take it out the traditional way, through the top
Old Jul 31, 2004 | 02:34 PM
grady's Avatar
grady
For those who removed the motor why did you do it and how long to put it back in? I am considering building a stroker and wanted to know how much out and back in time.
To Pulling the motor from top or bottom
