A4 leak
Old Jul 31, 2004 | 03:12 PM
02bluez28's Avatar
02bluez28
Default A4 leak
Well I got under my new vette a few days ago and there was some kind of oil coming from the rear. then last week I took it to the dealer for a free oil change and they had it up on the lift and the oil was coming from the trans pan, can not get the car in till the 12th so how how do you check the fluid since there is no dip stick and where dose the fluid go in at. I had A camaro before this vette but nothing is in the same place bit the motor Any thing to look out for on the 04,
Old Jul 31, 2004 | 03:24 PM
SFVetteman's Avatar
SFVetteman
In order to check the level on the trans you need to get it up in the air with the motor running. There is a plug on the drivers side of the trans pan. Remove the plug and Dextron III ATF in until it overflows out the hole and reinstall the plug
