Cartek Gear Special
Old Aug 4, 2004 | 01:15 PM
Dave_Busch's Avatar
Dave_Busch
Default Cartek Gear Special
We have just received our long awaited 3.90 and 4.10 C5 gears.
We will offer all C5, 3.42, 3.73, 3.90, and 4.10 gears installed in the car for $1095.
This special is for 3 series carriers (3.15 or 3.42 differentials). It includes labor to remove and reinstall in your car. Labor to disassemble, clean, inspect, bearings, seals, your choice of gears, and labor to assemble.
We also can upgrade your driver side output shaft for an additional $350.
We will also be offering the same special for mail order, the price is $895 with core exchange.
A4 cars add $100 for programming.
Rear take off assemblies are available for cars originally equipped with a 2.73 ratio.
This special will be valid until September 15Th.
Call us at the shop to place an order at 908-317-4496 Monday thru Friday 10AM to 6PM E.S.T. , or contact me at davebusch@cartek.net. Installs are available Monday thru Saturdays.
Old Aug 4, 2004 | 04:02 PM
juiced's Avatar
juiced
Is it 895+ core charge? How much is the core charge.
Old Aug 4, 2004 | 04:14 PM
Dave_Busch's Avatar
Dave_Busch
The core charge is $500.
Old Aug 4, 2004 | 05:53 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Where are you guys located?
Old Aug 4, 2004 | 06:13 PM
juiced's Avatar
juiced
I think they're located somewhere in Jersey
Old Aug 4, 2004 | 06:22 PM
jmzvet's Avatar
jmzvet
Can you put 4.10s in a 2.73 case?
Will you take a 2.73 case as a core?
Old Aug 4, 2004 | 07:51 PM
Dave_Busch's Avatar
Dave_Busch
I am sorry, we can't. I can supply you with a take out 3 series rear for $500.
Old Aug 4, 2004 | 08:05 PM
T_Vert's Avatar
T_Vert
i have a 4.10 carrier now that has the speed sensor ring offset, can you guys fix this?
Dave
Old Aug 4, 2004 | 08:06 PM
juiced's Avatar
juiced
hey are all 04 6 speed carriers 3 series
Old Aug 4, 2004 | 09:36 PM
Spinal Sh0ck's Avatar
Spinal Sh0ck
TTT for ya Dave and may I suggest any one doing this upgrade might as well go for the hardened output shaft.. while the rear is apart any one with expierience.. will tell you that .. Nothing beats the help less feeling when those stock shafts snap... Witnessed.. 2 Z06's on BFG drag radials do there burnout.. then .. snap the stock shaft when they tried to launch at a ATCO track rental day just my .02 but i would'nt even think twice.. about this upgrade..
Old Aug 4, 2004 | 10:03 PM
Mitch C's Avatar
Mitch C
In a word yes, you should have 3.42 gears if your gears are stock.
Old Aug 4, 2004 | 10:33 PM
brent eb02's Avatar
brent eb02
good deal!!!
Old Aug 5, 2004 | 07:31 AM
mowrey96's Avatar
mowrey96
Ttt
Old Aug 5, 2004 | 01:35 PM
robz's Avatar
robz
Great mod for the price!
Old Aug 5, 2004 | 05:07 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In V Veteran
Great price Dave
Old Aug 5, 2004 | 05:32 PM
ragtopws6's Avatar
ragtopws6
I will have my 3.42 rear carrier for sale as a core after 8/7/04 if anyone need one.
Old Aug 5, 2004 | 10:15 PM
Dave_Busch's Avatar
Dave_Busch
Thanks guys. Yes all 6sd cars have 3.42 gears, A4 cars can come with 3.15 or 2.73 gears.
To Cartek Gear Special
Old Aug 5, 2004 | 10:31 PM
jl240z's Avatar
jl240z
Default diff questions
When you do the conversion do you put in all new bearings & seals? Can I send mine and get the same one back? Do you prep the outside of the case in any way or just clean it up? Some cores can come in looking pretty nasty or have corrosion on them. My car has about 28k miles on it and the case looks like new. If you tear it down isnt it better to put all new bearings in it anyway? I swore I was going to hold off spending for any more mods for now, but this is very tempting. What would the turnaround time be for upgradeing mine and sending it back? I just have to decide 3.90 or 4.10. I thought the M6 cars had the 3.73 rears as stock, also why does only one side need the heavy duty output shaft?
Old Aug 5, 2004 | 11:56 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
DAVID:
If i send you my Getrag 3.73 gears (ring and pinion 100% perfect) in its housing unit that is cracked all the way through, how much would it cost me to send me a fully installed 3.73 or 3.90 complete diff. unit all set up (and ready to be bolted into my car) including shipping to Chicago. What would be the price without a hardened output shaft less the credit for my getrag 3.73 ring and pinion that i would send you in its cracked getrag built 3.73 diff. housing unit/rear carrier? Pleae note that the ring and pinon 3.73s i would be sending you are 100% perfect as the rear diff. unit did not implode/hand grenade, but simply was leaking when i yanked it and saw that it had a crack all the way through. Car was running fine when i yanked the carrier out of the car, etc. and the 3.73s should be 100% reusable. If it would be cheaper, how much to simply reinstall my 3.73 gears into a new housing unit that you would supply and i would ship the complete cracked getrag 3,73 unti with gears installed inside, etc.
Thanks bro and please send me a PM or email as i am ready to get my 3.73s fixed up asap!
Jim P. aka MTI 427 Roadster
Old Aug 9, 2004 | 10:28 PM
Dave_Busch's Avatar
Dave_Busch
We hot tank all housings and always prefer to use your original rear. We do reject bad cores from time to time. Yes we do replace the main bearings.
