early rods vs. late rods
Old Aug 4, 2004 | 04:36 PM
FRC Rob's Avatar
FRC Rob
Default early rods vs. late rods
I'm told that there are some differences between early rods and late rods...I've got an early car (1999 FRC)... are my rods really different, or is only the bolts? If it's only the bolts,I can swap out for ARP bolts (easy); otherwise it's a whole rebuild with better rods to bring me up to later standards. I'm looking to cam & head my car , but I'm concerned about reving it too high with these early rods. What's the story with the rods in early cars?
Rob
Old Aug 4, 2004 | 05:03 PM
Jackal's Avatar
Jackal
I dont think the rods are much different at all. I have a 98, and my stock rods looked and felt EXACTLY the same as a set of 02 zo6 rods that I put in. ( I had a spun rod bearing).
Old Aug 4, 2004 | 05:22 PM
torchredfrc's Avatar
torchredfrc
I have never seen any other rods but I have a early 99 FRC and the rods in mine were 2 piece. I replaced them when I did my CAM with hardened rods from MTI. If you are doing a cam, you will need new springs and should probably replace the push rods too. As far as I know, the head bolts are all the same on 97-04's. I would recommend you purchase them as a kit (GM Part #12498545 -- my dealer showed another part number for the head bolt kit and this part for any gm small block... i ordered the part number listed then later had to buy another set of the bolts individually, they are the exact same bolts and cheaper than the part number the dealer showed for the vette) from your local dealer. GMPartsDirect had them but after shipping they were almost $20 a set more expensive than my local dealer. You can purchase the bolts individually from your dealer but they will come out to almost $60 per side when the kit is like $21.
Old Aug 4, 2004 | 05:46 PM
torchredfrc
I compiled this excel file when ordering parts for my cam swap and thought it might help you.
Required parts
Old Aug 4, 2004 | 06:03 PM
SNW Vette's Avatar
SNW Vette
Default Early Rods
Hi,
The story I heard about the early rods is that some of the early LS1’s that Lingenfelter builds for ASA racing broke rod bolts. Chevy upgraded the bolts for the 2001model year in response and this solved the problem. There are aftermarket bolts available from Katech & ARP that are even stronger than the late Chevy parts. I used Katech in my ’99 but would go with the best ARP next time.
Good luck,
Steve
Old Aug 4, 2004 | 06:47 PM
ArKay99's Avatar
ArKay99
Originally Posted by SNW Vette
Hi,
Good luck,
Steve
I have a 99 FRC and I am doing what you are planning to do. I am changing the rod bolts, doing the LS6 pcv conversion with an AMW catch can, and doing a h/c swap. changing the rod bolts is not trivial. You have to either remove the motor and do it on a stand or leave the motor in the car and support the motor from above. THe reason for supporting the motor from above is because the motor is mounted to the crossmember and the crossmember must be removed to get the pan out. Also the pan has rivets locating it to the block. They must be drilled out to remove the pan. All this must occur with the motor hanging in the air supported from above.
Old Aug 4, 2004 | 07:36 PM
Jackal's Avatar
Jackal
I have never seen rivets in the oil pan. Are you sure?
Old Aug 4, 2004 | 07:42 PM
torchredfrc
Hi,
Good luck,
Steve
Am I thinking of different rods & bolts?
Old Aug 4, 2004 | 11:35 PM
ArKay99's Avatar
ArKay99
It says they are there in the service manual. It says to drill them out and don't worry about replacing them when you reinstall. I'll keep my trusty Ryobi ready just in case.
Old Aug 4, 2004 | 11:44 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
The pop rivits hold the gasket to the pan they do not go into the block.
Old Aug 5, 2004 | 09:14 AM
Heretic's Avatar
Heretic
ARP tech says you need to hone the big end after installing their LS1 bolts. I was going to upgrade the bolts until I found this out.
If you are going to replace the bolts with ARPs the engine is coming out. If the engine comes out you might as well upgrade the rods and pistons to forged units. It costs $300-$400 for labor and ARP bolts for a set of stock rods, I've seen eagles for $600.
I bought a block, and am going to build a new shortblock when I get done with my 69 Camaro.
Old Aug 5, 2004 | 09:59 AM
LivinTheDream's Avatar
LivinTheDream
Hi,
Good luck,
Steve
I read something similar in the LS1/LS6 Performance Guide
Old Aug 5, 2004 | 10:40 AM
FRC Rob's Avatar
FRC Rob
Some guys on ls1tech.com have swapped out rod bolts in the car (without resizing the big ends). And, it looks like a much easier job on a C5 than an F-body (which requires dropping the k-member). I'm kind of on the fence now, though. The labor to swap 'em out in the car does not scare me...it actually looks pretty easy. I'm mostly concerned now about whether you really need to resize them. Anybody here actually done this? (I realize this method isn't the "right" way, but going through the whole motor just isn't in the budget right now.)
Old Aug 5, 2004 | 11:55 AM
ArKay99's Avatar
ArKay99
I talked to ARP and they told me the same thing. However, the LS1 rods are cracked and can't be resized unless you hone them assembled. I talked to Katech, the other company that makes rod bolts. They told me you don't need to do any rod resizing with their bolts. You change them one at a time so the bearings don't shift. There was a member on this forum that did this using Katech bolts on his 2000 over the winter and was successful. Katech provides instructions with the bolt kit. I'm planning on doing this as soon as the bolts arrive.
The big issue of changing the rod bolts with the engine in the car is how to support the engine from above. The crossmember has to be removed to gain access to the oil pan bolts for removal and the service manual states there are several rivets used to locate the oil pan that have to be drilled out. Kent-Moore makes a fixture that mounts to the shock struts and supports the engine so the crossmember can be removed and from there the oil pan can be removed. The total cost for this fixture is around $900 so it's out of the question for the one time user. I am investigating building my own support in order to do this. It might also be easier to just take the motor out and do it on a stand since I doubt it's an item that can be rented.
Old Aug 5, 2004 | 12:32 PM
Mr. Jones's Avatar
Mr. Jones
you should always resize the large end/crank end of the connecting rod when changing bolt. if your worried able the stock bottom end it makes no sense to change bolts and not resize. A potential hand grenade!
now that the pan is out, the crank is out, the pistons are out with rods and you have no good way to support the motor0- lets think about this.
after all this you will prabably say to yourself -it would have been easier to have removed to engine.
Now you can do all mods/assembly on a stand, clean and right.
short cuts will bit you in the end
Old Aug 5, 2004 | 12:33 PM
Heretic's Avatar
Heretic
You could use an engine hoist or even a jack handle across the frame rails to support the front of the engine.
I have a set of rods that I was going to magnaflux and resize. Maybe I'll just buy the ARP bolts, and measure before and after to answer definativley.
I can't see how increasing the clamping load would distort the bore. The clamping force is concentrated on the "ears" of the big end, so unless you are really clamping down, there should be no measureable distortion. Removing the bolts from a standard rod, with pressed in bolts is a fairly traumatic process, so the need to resize there is obvious.
Interesting discussion. Too bad the tuners who are so ready to pimp their products don't jump in on these.
Old Aug 5, 2004 | 12:43 PM
Mr. Jones's Avatar
Mr. Jones
pressing in different bolts that could move the cap even a c-hair
is enough to cause a mismatch. how the head of that bolt loads the
rod can add a different pressure point. why take the time to do all this work and then risk a problem at high RPM and make a real big mess of thinks.
To early rods vs. late rods
Old Aug 5, 2004 | 12:52 PM
Heretic's Avatar
Heretic
The LS1 rods are a cap screw type bolt, there is no pressing, hence my pondering of why arp says to resize.
Old Aug 5, 2004 | 01:00 PM
Mr. Jones's Avatar
Mr. Jones
I didn't know that. I would think they don't want to be responsible for any possble mismatch. why not ask a site tuner/builder for there recomendation.
Old Aug 5, 2004 | 01:46 PM
FRC Rob's Avatar
FRC Rob
I'm going to give it a try. I'll be doing heads & cam at the same time, so I can just attach a chain to the block and use an I-beam hoist to hold it up while I swap out the bolts from underneath. (There's a good thread on ls1tech.com covering the procedure...I don't know if the moderators allow linking to other boards, so I'll let you go look it up yourselves if you're interested.) Honestly, this looks like a very easy job...I can't see it adding more than an extra hour or two to the H/C swap. I guess I'm more afraid of spinning too much rpm with stock rod bolts than tackling this little project. Time to start ordering up some parts!
