The flow from an electric pump is considerably less at higher rpms....I had a Meziere and it overheated/detonated my motor to a degree that it lifted the heads and broke the ring lands on 7&8. I'm getting the shortblock bored .005" over, new pistons, new main and cam bearings and I'm using an Evans high capacity mechanical pump..... the Evans flows about 25% more than the stock pump. DON"T GO ELECTRIC !!!!
