new owner needs help/info
Mods to date in order: slotted cold air inserts, z06 air box lid, K&N replacement filter, high flow air bridge & sleeve, msd wires, ngk tr55 plugs, 180 stat, magnaflow x-pipe, b&b bullett exhaust, diablo sport predator.
Loaded tune and car was put in reduced power mode - would just die if clutch let out all the way - after three try's and many error msg on programmer screen factory program was reloaded. contacted diablo, they said i needed version 1.13 to work with my car; still waiting for replacement box to show up.
My problem is the car is very hard to start and has made rattel/knocking sounds at start up, seems to idle fine and low speed ok. Rather leary of using it, i think the factory program was corrupted somehow.
How can i get the factory tune back, beside going to the dealer & will they be able to tell it's been played with. Just got the recall notice for steering lock & understand they reflash pcm, concerned their equipment will record the tampering and create a problem if some sort of damage was caused by the box.
They will just flash in a new program for you! Just plead ignorant! "Who,,,,, me,,, mess with the computer,,,,,,,,NO way,, I would NEVER do that!
You could disconnect the battery and erase the memory and see if that helps!
Give that a shot!
Let us know how you make out!!
BC
