Well I Just Ordered the Kooks
Price was just too good to pass up, and I looked at all the major header brands spoken of here and narrowed it to Kooks or LGs. . Getting the whole system for a little bit more than what some manufacturers want for just headers.
There might be easier to install headers, but when I weighed in performance, build quality, customer support, company reputation, and price/value, I decided I could live with the difficult install.
The LGs were close, but in the end the price deterred me. What they give you in ease of install is offset by price. And what Kooks gives you in price, is offset by ease of installation.
They should be here soon, so it will give me plenty of time to review the install tips and advice here and over at the Z06 forum. If I get stuck, I can always consult you guys, so what have I got to lose.
and good luck on the installStan
I hate you !!!
No... not really. I just envy you; as this will (hopefully) be my next mod somewhere down the road.
Please keep us posted on the install and results.
Good tip above about cleaning them.....mine came in real dirty inside. For the headers I used a garden hose and sprayed water through them and let them dry in the sun. For the "X" I used a cloth and carefully wiped out the upstream side (i.e. so the crap wouldn't clog up the cats).
will you adopt me
Someone brung up a good point about cleaning the inside of the headers... I did notice a lot of metal grit in the headers and x-pipe too and took a rag and flexible rod and pushed it through the pipes a few times to clean out as much of it as I could as well as the intake of the x-pipe.
Pretty tiny stuff... maybe would have blown through the cats (?!) but a preventive measure to not clog the cats. Definitely one step Kooks should take before shipping them out.
The install is not that hard and details like that is another reason I'm glad I did the install myself.
Good luck and look forward to reading the results.
Don
Sort of looking forward to it. Maybe I'm a glutton for punishment but I have read the install procedures incessantly.
I will be attempting to do this without removing the starter or the alternator bracket. Some here have done the install without removing these. . If I have to remove these I will of course.
The only part that has me leery is the steering linkage step. I understand that bolt can be tough to break.
Jacking the motor up should be no biggie. I know I should loosen the mount bolts from the bottom down to just a few threads, but should I loosen them on both sides or just the side that I am working on before jacking?
The starter I could not see any way around it but it was one of the easier pieces to remove.
the steering linkage was hard until I found an extension to my rachet handle long enough to give me a leverage... basically a 3 foot pipe and it turned easily.
Motor mounts.... remove the bolt on the side you are lifting with the jack. the other side leave the bold on with a couple of threads showing. i believe it will help with the tilt angle.
if you jack with removing both bolts, eventually the other side of the motor will lift up too and you wont get the angle you want the motor to tilt.
don't forget the 2x3.
i don't know if my kooks posts are still on this forum but i'm pretty sure there on the 'other' forum.
good luck.
