Over heat Help
Old Aug 11, 2004 | 02:04 PM
sid459's Avatar
sid459
Default Over heat Help
have a 99 that recently indicated low coolant on the dash. When I added the dexcool and water the vett is now running hot and still showing low coolant.
Ive tried filling it with the engine running and with it off. It has even boiled out when I try to fill it while it was running.
Has anyone had this problem? and what is the fix.
Help
Old Aug 11, 2004 | 03:40 PM
gpflepsen's Avatar
gpflepsen
Cruise-In II Veteran
I'll start with the obvious. Have you cleared any debris from in front of the radiator? What is hot? What does the coolant temp say on the DIC?
Old Aug 12, 2004 | 08:50 AM
sid459's Avatar
sid459
Yes I have made sure there was nothing in front of the radiator.
After worm up it reads 217 - 221 for a few. Then it start to rise up as high as 247 -250. could this be a therestat problem?
Old Aug 20, 2004 | 06:01 PM
gpflepsen's Avatar
gpflepsen
Are the fans coming on? If the fans aren't running, you can overheat and boil over some fluid. The car won't overheat with normal high speed driving, but stop-n-go will cause overheating.
Old Aug 20, 2004 | 10:08 PM
washguy's Avatar
washguy
Maybe the waterpump is on its way out?
Wash
Old Aug 20, 2004 | 10:33 PM
Crow Hunter's Avatar
Crow Hunter
Default heating problem
It sounds like the thermostat is not opening fully. My '97 was doing the same thing, and I installed a Hypertech 160 'stat, and my coolant temp now averages around 178 while cruising, and no hotter than 206 in traffic, idling, with outside temperature abount 96. I also drained the old Dex cool and replaced it with fresh. It is a very easy job.
Old Aug 20, 2004 | 10:41 PM
VERYSOON's Avatar
VERYSOON
I would say that is a classic description of a thermostat that is not opening.
let us know!
g
Old Aug 20, 2004 | 11:12 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Is the coolant circulating? Are the fans coming on at all? You may need a new radiator cap, thermostat or have the fans checked. Dont ever try to open the rad cap when the car is 250 deg... that is way too hot!!
VR
Old Aug 21, 2004 | 08:30 AM
Richin Chicago's Avatar
Richin Chicago
This is a bit of a thread diversion, but do you really coolant temperatures that low when cruising? What does that leave your oil temperature at?
Old Aug 22, 2004 | 06:45 PM
gpflepsen's Avatar
gpflepsen
I would be easy to see if the thermostat is opening, just feel the radiator return hose (of course don't burn yourself). If it is hot (and the radiator) the thermostat is opening. You may have a bad seal on the radiator fill cap. There is a TSB for fixing this, so it is a known problem with GM. The TSB calls for polishing the radiator fill cap seat area with 400 grit wet/dry, backed by a wooden dowl or stick. Replace the radiator cap with a new one. If the coolant system isn't pressurizing, it will boil oved and then overheat after the coolant is puked out.
To Over heat Help
