Torque setting needed and Brake line question
Old Aug 11, 2004 | 07:06 PM
Piranha's Avatar
Piranha
Default Torque setting needed and Brake line question
I am replacing my stock brake lines on my '03 Z06 with stainless steal ones. Does anyone know if there are torque settings for the line fittings. I am also putting in speedbleeders, are there torque settings for those as well? Also, just to confirm, do the longer lines go on the rear?
TIA
Old Aug 11, 2004 | 07:13 PM
Patches's Avatar
Patches
Bleed screw - 106 in. lbs (that's INCH-pounds)
Caliper guide pin bolt - 23 lb. ft.
Inlet fitting bolt - 30 lb. ft.
Bracket mounting bolt - 125 lb. ft.
All my Goodridge lines were the same length but perhaps the fronts are longer to accomodate steering action.
Old Aug 11, 2004 | 07:15 PM
Piranha's Avatar
Piranha
Default Thanks,
Thanks for the numbers.
My lines are goodrige as well and two of them are ~1" longer.
Just got them from the LAPD GP.
If anyone else knows, chime in.
Thanks,
To Torque setting needed and Brake line question
