battery life
Old Aug 16, 2004 | 02:48 AM
dmaccor's Avatar
dmaccor
Default battery life
Is 3 years good for a Zo6 battery? Mine just died while in having a trany and gerabox oil change.
I dont know if the guys did something to cause it to die
The new one was $89,,plus $150 for the 2 oil changes> is this a little steep or normal?
Old Aug 16, 2004 | 02:51 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
Probably about average there in Houston. Here in "sunny" AZ a battery is lucky to last 2 yrs. Mine just went out while I was at Costco with the wife. Came out and it was dead as the proverbial "doorknob". Definitely consider the Optima Red Top as a replacement. Sure you've heard the leaking battery horror stories.
Old Aug 16, 2004 | 03:42 AM
TorqueWinsRaces's Avatar
TorqueWinsRaces
So, is it fixed? And if so, what was the problem? Inquiring minds want to know...
Old Aug 16, 2004 | 03:44 AM
TorqueWinsRaces
I just realized that you are not who I was thinking of.
Old Aug 18, 2004 | 02:45 AM
dmaccor's Avatar
dmaccor
When the old one came out..I checked under the batterry box for any leaks..It was OK , but alot of road dust and gunk there!!!!
Why is the computer under the battery...could'nt they find anywhere else to put such an important part of the car!!!!
Old Aug 18, 2004 | 03:16 AM
Rickk's Avatar
Rickk
I got 5 years from the original delco battery in my 99. It never leaked. I replaced it with an Optima Redtop.
Old Aug 18, 2004 | 04:41 PM
roscoe118's Avatar
roscoe118
In '01 and '02 GM went with the AGM (Gel) batteries, I think in an attempt to stop the "acid leak" problems. From what I can gather here, these batteries do not have as long a life as the lead acid batteries.
My '02 battery died last night, after picking my car up from the dealer where it was in for warranty work (rear diff. seal leak and passenger window regulator ) yesterday.
In this summer heat they are more prone to dying suddenly. And believe me these AGM batteries give NO warning.
3 years sounds pretty good to me, in this Texas heat, if it was an AGM battery.
Old Aug 18, 2004 | 06:44 PM
Richin Chicago's Avatar
Richin Chicago
Heat and cheap Delco batteries are the enemy. I am on my third battery in 4 years.
Old Aug 18, 2004 | 11:37 PM
Dave68's Avatar
Dave68
My OEM AGM battery is more than 3 years old and still as strong as the day I received the car. I have no reason to believe it won't go another year or two. When it finally goes, I will consider one of these batteries:
http://www.odysseyfactory.com/
Old Aug 19, 2004 | 10:16 AM
topless99's Avatar
topless99
I am replacing the original battery in my 99 convertible this week.
Old Aug 19, 2004 | 08:07 PM
Mel 2001's Avatar
Mel 2001
My warning was the DIC defaulted. After installing Optima Redtop, no more default.
To battery life
