A4 Trans temp range
Old Aug 16, 2004 | 06:29 PM
Gray Weasel's Avatar
Gray Weasel
Default A4 Trans temp range
Just a Question>>>>>>>What is the temp safe op range for the trans...
Old Aug 16, 2004 | 07:24 PM
Doubletap's Avatar
Doubletap
St. Jude Donor '08-'09-'12
mine runs 185 - 195
Old Aug 16, 2004 | 09:04 PM
LeMansBlue04's Avatar
LeMansBlue04
I have posted this before but...
If you go TCI's web site they say it should be between 175 and 225.
Old Aug 16, 2004 | 10:10 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I got up to 203 yesterday, it was hot outside with no breeze. I do have a 3500 stall.
Old Aug 16, 2004 | 11:58 PM
jim2527's Avatar
jim2527
My oil, trans and coolant temps are always close. In stop and go traffic they all climb into the 225-230 range. That makes sense considering the turn on temp for the fan is in that range. On the highway the temps are all near the thermostat opening temp.
Old Aug 17, 2004 | 09:36 AM
rapid robert's Avatar
rapid robert
Trans temp 192, Oil 210, water 187, and oil 43 lbs. That was after 3 hr. drive on I- 75 and 95 % outside.
Old Aug 17, 2004 | 10:18 AM
Vector's Avatar
Vector
My A4 Tranny Temp use to regularly go to 220 F after a hard pull. I had a Tranny Cooler installed last month with a H/C pkg. w/ 160 Deg Stat and fan settings reset to come on earlier. Tranny temp now stays around coolant temp or 170 to 180 even under enthusiastic driving. I've seen 200 once on the Tranny Temp after three back to back 1/4 miles runs - happily all in the mid 12's.
Old Aug 17, 2004 | 01:02 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
I've heard that it will give you a warning when the tranny temp gets really hot; I think 235+ or 240+. With a 3.73 diff and a 3500 stall t/c, I've seen my tranny get in the low 230's. Casually driving down the highway, it is in the 210's with that setup.
Old Aug 19, 2004 | 08:29 PM
love2dye4u's Avatar
love2dye4u
Where did you buy the tranny cooler, and how difficult was it to install the cooler?
Old Aug 20, 2004 | 09:07 AM
Vector's Avatar
Vector
Had the Tranny cooler installed by 21st Century Muscle Car in Dallas,TX area at the same time I had the H/C pkg anf Torque Converter installed. It is larger than most coolers I have seen. Looks about 12"x18" and mounts against the front of the radiator -sorry I don't know the brand name. They had to weld some fittings on the fluid lines and cut openings in the radiator shroud to fit the lines through. With the engine out, the install looked easy . Seriously, I think installing wouldn't be too bad for a wekend project - getting the right fittings and plumbing would be the most difficult I think- but this is from a guy that had the pros do it!
To A4 Trans temp range
