1999 C5 Active handling error code
Old Aug 17, 2004 | 09:33 PM
wdhille's Avatar
wdhille
Cruising
Default 1999 C5 Active handling error code
Anyone ever have an active handling error 1287? Any clue how to fix it? It looks like the steering position sensor. I tried to reset it, and it came back, so it's not a ghost.
I kind of hate to bring it to the dealer, so if anybody knows of a good Corvette shop in the Annapolis Maryland area, I'd appreciate it!
Thanks in advance
Wayne
Old Aug 17, 2004 | 11:49 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
It sounds like the steering position sensor needs to be replaced, and that's not easy. There are a couple older threads you can search for here that will show you how to do it yourself, but you need to be a decent mechanic. It requires the removal of the entire steering column, as the sensor is a ring around the bottom of the column. I just lived with my error message until I sold the car...
