What is code 2252?
Old Aug 21, 2004 | 04:51 PM
IrishFan's Avatar
IrishFan
Default What is code 2252?
I know it means "key cylinder switch fault". But what what is the root cause of this code?
It's a 'history' code so I'm not too worried about it...but I'm still curious what would cause it.
Old Aug 21, 2004 | 07:08 PM
Richin Chicago's Avatar
Richin Chicago
CIRCUIT DESCRIPTION
The LH door key switch circuit provides input to the LH Door Control Module (LDCM) when the LH door key switch is rotated the UNLOCK position. This input allows the LDCM to detect when the door is unlocked. This information is sent on the serial data line and used by other systems to execute certain functions (UTD, Illuminated entry, hatch release, etc.). The LDCM provides both power and ground to the LH door key switch. When the LH door key switch is rotated the UNLOCK position, a ground is supplied through the LH door key switch to the LH door key switch input which is pulled low. When the LDCM detects low voltage on the LH door key switch input, the LDCM will UNLOCK the driver door and will also send a message on the serial data line to the RH Door Control Module (RDCM) to UNLOCK the passenger door. The LDCM monitors the LH door key switch signal circuit and determines how long a ground (switch activated) has been applied. If the ground is applied for longer than expected, a malfunction is present and a DTC will set.
CONDITIONS FOR SETTING THE DTC
The LDCM detects a low voltage level (short to ground) at the LH door key switch signal circuit.
Condition must be present for 20 seconds .
ACTION TAKEN WHEN THE DTC SETS
Stores a history DTC B2252 in the LDCM memory
This DTC can only be set as a history code even if the malfunction is current.
No driver warning message will be displayed for this DTC.
CONDITIONS FOR CLEARING THE DTC
The LDCM no longer detects a low voltage level (short to ground) at the LH door key switch signal circuit for longer than 20 seconds .
Use the IPC clearing DTCs feature.
Use a scan tool.
DIAGNOSTIC AIDS
The following conditions may cause an intermittent malfunction:
There is an intermittent short to ground in the LH door key switch signal circuit.
The LH door key switch is shorted to ground internally or is sticking.
The LH door key switch was activated for longer than 20 seconds .
Using a scan tool, select LDCM inputs and monitor the Door Key Unlock Switch status. If the scan tool displays ACTIVE, disconnect the LH door key switch and check if the Door Key Unlock Switch status changes to INACTIVE. If the Door Key Unlock Switch status changed, then replace the LH door key switch. If the Door Key Unlock Switch status did not change, then check LH door key switch signal circuit for a short to ground.
If the DTC does not reset after the code is cleared, then the problem may be intermittent. Perform the tests shown while moving related wiring and connectors. This can often cause the malfunction to occur. Refer to Intermittents and Poor Connections.
TEST DESCRIPTION
The number(s) below refer to the step number(s) on the diagnostic table.
Tests for the normal state of the LH door key switch using a scan tool. The scan tool will display the normal state as INACTIVE, and ACTIVE when the switch is activated.
Tests if the LH DCM is able to detect a change in LH door key switch state. The scan tool will display the normal state as INACTIVE, and ACTIVE when the switch is activated.
Tests for a stuck or shorted LH door key switch. If the LH door key switch is stuck or shorted, the state will change from ACTIVE to INACTIVE when the LH door key switch is disconnected.
Tests for a short to ground in the LH door key switch signal circuit.
