Help with electrical connectors
Old Aug 24, 2004 | 08:31 PM
GKrenn's Avatar
GKrenn
Default Help with electrical connectors
I am trying to diagnos a possible electrical problem and don't want to force any of the electrical connectors. I notice some hava a white tab that prevents the connector from coming loose, do these simply pull out and push back in to replace? Also, how does the pigtail connector on the EBCM disconnect. Any help is greatly appreciated.
Old Aug 24, 2004 | 10:31 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
the ones with the tab that goes thru a loop should come right out and slide back. in some of the connectors have a stress relief that you pull on.Do not just pull the wires look closely at the connector you will see how it disengages.Just take you time you will understand when you stare at it for a little while .
