Sticking Clutch pedal
Old Aug 24, 2004 | 10:24 PM
Hammer's Avatar
Hammer
Default Sticking Clutch pedal
I was getting on the car a little and the clutch pedal got stuck down, the gear engaged but I had to pump the pedal a few times to get it up.
Does anyone know what went wrong?
Jim
Old Aug 24, 2004 | 10:44 PM
jmzvet's Avatar
jmzvet
Use the search feature and you'll find several posts on this exact topic.
My 03 is at the dealer right now and they are replacing ALL the clutch components under warranty. Hopefully it will cure the problem.
Old Aug 24, 2004 | 10:55 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
faulty slave cylinder for clutch
Old Aug 24, 2004 | 11:02 PM
Hammer's Avatar
Hammer
Would the slave cylinder be covered under extended warranty?
Old Aug 24, 2004 | 11:38 PM
T_Vert's Avatar
T_Vert
id put money on the pressure plate. I had same problem, replaced slave and did nothing for the problem.
dave
Old Aug 25, 2004 | 11:17 AM
HurricaneZ's Avatar
HurricaneZ
same problem here, developed after the installation of the procharger, I've yet to be able to row through the more than 2 gears. Yet the clutch has not slipped once. Its going to be a while before I can get a new clutch since I'm now a poor college kid
Old Aug 25, 2004 | 02:12 PM
sweet97c5's Avatar
sweet97c5
Default sticking clutch
must check pressure plate torque,if not torqued properly will cause press. plate to woble enough to cause slave cylinder to malfunction.All the ones I have checked i had to replace complete clutch assymbly,slave and master cylinder.There is a TSB on this problem.
Old Aug 25, 2004 | 04:32 PM
Paras's Avatar
Paras
Default sticky clutch pedal
I have the extended warranty and I just had my clutch swapped out by the Dealer at no cost! Apparently GM has information out on this to the Dealers where they should replace your whole clutch if this problem occurs. The problem only happened to me when I shift at really high (redline) RPMs
Old Aug 25, 2004 | 08:34 PM
allanlaw's Avatar
allanlaw
You are lucky. Local dealer here said he couldn't duplicate the problem so no fix under warranty, even though I gave him the GM info sheet. So, it was my treat (at LAPD) to get the full, newer Z06 clutch parts upgrade. Refilled with high-temp brake fluid. The clutch has been perfect ever since.
To Sticking Clutch pedal
