Alex,
I,m not sure which years but I have a complete 2002 system, from Z06 manifolds, the good mid section and rear mufflers. In 2002, the exhaust manifolds were Z06. Where are you located?
Alex,
I have a 1999 coupe and was wanting to install Z06 exhaust manifolds and mid section . what years will work.
I installed the 2002 z06 manifold and cat section in my 1999 vette. You will need a new air tube for the passenger side (around $20) and the dip stick needs to be moved alittle to make it work. I was able to bend the dip stick hold on bracket and it works and looks good. Other than those 2 items its a direct bolt on.
I really cant tell yet, Ive been doing alot of mods but I figure the newer cats definently flow better than the 99's and the manifolds flow better than the 99's.
