Service Engine Soon Codes with Halltech!!!
Old Aug 27, 2004 | 06:57 PM
cdibi's Avatar
cdibi
Default Service Engine Soon Codes with Halltech!!!
I just put the Halltech Stinger intake in and ever since I have been getting service engine soon codes. It ran fine for the first few miles and then the message came on. I turned the power off and re-started and was fine for a few days. Today on my way home from work it happened over and over again with all sorts of messages: Check tire pressure, active handling system, etc..
Not sure if it has to do with the intake or not. Any ideas?? Help!!
Old Aug 27, 2004 | 11:17 PM
Dave68's Avatar
Dave68
It sounds like it could be one of two things, well - maybe three.
First, check all electrical connections under the hood (that you can see) and especially the MAF connection.
Second, check all couplings from the filter to the throttle body, especially the smooth coupler to the throttlebody seal.
Third, you may have drained your battery if any of your car lights remained on for long periods of time. When I was documenting my cold air mod, I had to disconnect the negative battery cable because I kept bumping into the hood, which caused the sleeping hood light to pop back on. If your battery is weak for whatever reason, you could get crazy code pop-ups on the D.I.C.
Good luck!
Old Aug 28, 2004 | 12:33 AM
Subw00er's Avatar
Subw00er
Just curious... Does anyone with an 04 c5 or 04 z06 _not_ get check engine codes with the halltech?
Old Aug 28, 2004 | 01:39 AM
Richin Chicago's Avatar
Richin Chicago
Find out what the actual codes are and post them:
http://www.stengel.net/diccodes.htm
To Service Engine Soon Codes with Halltech!!!
