squeeky noise from front right wheel,
Old Sep 2, 2004 | 10:34 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Default squeeky noise from front right wheel,
When I'm driving below 25-30 mph with my windows open, there's this squeeky niose that comes from the front right wheel area. If i put my foot on the brake (very slight pressure that the car barely slows down) the squeeking stops. Any ideas of what it could be or what can I do, before I have it looked at.
Thanks in advance
Old Sep 3, 2004 | 01:55 PM
DanielW's Avatar
DanielW
ttt
Old Sep 3, 2004 | 02:17 PM
Paul20850's Avatar
Paul20850
Cruising
I have the same squeeky wheel on my front left. Anyone have any ideas?
Old Sep 3, 2004 | 02:24 PM
Richin Chicago's Avatar
Richin Chicago
It, usually, indicates that the slide pins the caliper is mounted on aren't "sliding". The barkes pads aren't pushing away from the caliper far enough and the pads are making light contact. When you step on the brake you quell the vibration that causes the noise.
Pull the calipers and grease the slide pins with some synthetic caliper grease.
Old Sep 3, 2004 | 02:58 PM
DanielW's Avatar
DanielW
thanks. will try that this weekend.
To squeeky noise from front right wheel,
