I had a BCM issue a while back and needed to replace it! One of the reason the BCM went bad was corrosion from getting wet when the AC/Heater box drains got clogged! The corrosion shorted out circuits on the BACK of the board! I cleaned off the corrosion prior to taking the picture of it in an effort to save it. Cleaning the corrosion off the board changed the indications but did not correct all of them. Here are some photos of the BCM and the circuit board that is inside of it.
[IMG][/IMG] [IMG][/IMG]
This intergrated circuit was touching the inside of the box! (it left a distinc mark on the inside of the box) I do NOT know if it is suppose to touch the box or if it was part of the issue causing my BCM problems.
[IMG][/IMG]
