I need some help!!!!!!
Old Sep 4, 2004 | 01:43 PM
Lancer033's Avatar
Lancer033
Default I need some help!!!!!!
I've got a problem - I cracked my rotors on Thursday night at Hockenheim and am trying to change them out. They've only been on the car for about 3 months and 6K miles so they shouldn't be rusted on, but they aren't moving. I tried WD40 and beating them with a rubber mallet, then I got a couple of C-clamps and a 2x4 and tried to pull them out, and nothing.
I've spent all afternoon working on 1 rotor. What else is there to try, I'm out of ideas
Old Sep 4, 2004 | 05:41 PM
Lancer033's Avatar
Lancer033
Anyone?? there's got to be some other trick.
Old Sep 4, 2004 | 07:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LANCER033
Are you having a problem removing the front or the rears?
I have a few suggestions but need to know the fiollowing:
Front or rear??
Do you have the caliber brackets removed?
Are they OEM or aftermarket rotors?
Please get back to me.
Bill Curlee
Old Sep 5, 2004 | 03:16 AM
Lancer033's Avatar
Lancer033
It's the Front one, and yes the brackets are off, aftermarket rotors, They are zinc coated and the hat is powdercoated black if that matter?
Old Sep 5, 2004 | 09:16 AM
Richin Chicago's Avatar
Richin Chicago
Obvious first. The reataining clips are off of the lugs?
After that you just have to beat on it. There should be nothing else holding the rotors on other than corrosion. Try rotating the rotor about 30 degrees every time you hit it.
Old Sep 5, 2004 | 11:11 AM
Lancer033's Avatar
Lancer033
reataining clips are gone, threw them away when I replaced my 1st set of rotors - this is really getting frustrating.
I'll make ya'll the same offer I did to f-body Europe - a case of beer to anyone who can get the thing off.
Old Sep 5, 2004 | 11:15 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
If the rubber mallet is not working then try a BIG steel hammer... you are going to junk the rotors anyway... when in doubt.. use a bigger hammer.
VR
Old Sep 5, 2004 | 12:49 PM
Richin Chicago
Piece of wood, a really big hammer and a small rotation after every blow. Add anger!
Old Sep 5, 2004 | 01:24 PM
30yeardream's Avatar
30yeardream
Had this problem a week or 2 ago with customers car. Take a piece of 1"x3" wood. Turn wheels so front of rotors are pointed out and away from car. Wedge wood between rotor and Hub Strike end of wood with mallet to wedge rotor off. Rotate occasionally to get even relief of rotor. This is how we got them off. You will not hurt the rotors but then you already cracked them. Good Luck Mark
Old Sep 5, 2004 | 05:40 PM
Ls1Rat's Avatar
Ls1Rat
beat them to death
Old Sep 5, 2004 | 07:56 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Haven't ever had mine stick on, but they don't normally stay on the car very long either.
His advice above sounds like what I would try.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Sep 5, 2004 | 09:45 PM
vetterdstr's Avatar
vetterdstr
Cutting Torch?? Let me know if I won the case of beer?? Actually what I have been wanting lately is some Heineken draft...
VR
To I need some help!!!!!!
