Alarm problem
Old Sep 8, 2004 | 10:33 AM
Huckzilla's Avatar
Huckzilla
Default Alarm problem
My car is possessed
For no apparent reason, my car is now arming itself when I shut it off and both doors have been closed. Mind you, I did not change the Passive alarm setting on the remote (it's in the OFF position). The odd thing is, as long as the remote is in the vicinity of the car, it will keep arming itself until it's out of range. Is it possible that the battery in the remote needs replaced?
Looking for your suggestions to fix Christine
Tom
Old Sep 8, 2004 | 10:48 AM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
My friend is having the same issues... the dealer cant figure out why as of right now..
http://forums.corvetteforum.com/showthread.php?t=899827
Old Sep 9, 2004 | 12:15 PM
wwashing's Avatar
wwashing
Originally Posted by Huckzilla
My car is possessed
Tom
Try these:
Resynch the fob - stand next to car and press both lock and unlock until the horn honks.
Try setting the fob to passive on and then back to off.
Take the fob out of range and try your other fob.
If you continue to see the bahavior with the second fob then disconnect the battery (car battery) for 5 minutes. Reconnect and see if behavior continues.
See you dealer.
Old Sep 9, 2004 | 12:22 PM
Huckzilla's Avatar
Huckzilla
I'll give it a try. Only problem is I have only one FOB. Previous owner lost the other one and never replaced it.
To Alarm problem
