Z06 throttle response lag
Old Sep 10, 2004 | 08:16 AM
GrantR's Avatar
GrantR
Default Z06 throttle response lag
Hi guys,
So I picked up my new 2003 Z06 today. After driving around a bunch, the car is certainly entertaining But the most annoying thing about driving the car is that there is about a 1/4 second delay between what my foot does on the throttle and when the engine bothers to respond. I'm used to throttle-cable cars where the engine responds instantaneously, so I'm not sure if this is something that is just there and I have to live with it or if it is something that should be better and needs to be fixed. Is this delay there for other C5s too? It's very easy to test - while cruising, just to brief stabs of the throttle and see if the motor responds the instant you hit the throttle or a bit later. Same with lifting off the gas, it takes a while to stop applying power - I keep thinking the throttle is stuck open A guy at work has a 350Z which also has drive-by-wire throttle, but has zero response lag. Can this be fixed in any way?
Thanks for any information/advice/tips/etc
Grant.
Old Sep 10, 2004 | 08:54 AM
mdhmi's Avatar
mdhmi
A ported TB will help you.
Mark
Old Sep 10, 2004 | 09:16 AM
C6~Missle's Avatar
C6~Missle
I have an 04 Z06 and notice no lag. My 99 did not have any lag either. Check to see the TB is clean and that there is nothing binding the throttle plate.
mike
Old Sep 10, 2004 | 11:42 AM
freefall's Avatar
freefall
I have the exact delay you describe - it's on all the other c5s i've driven. I'm not sure for the technical explaination of why it's there, but it is annoying.
Old Sep 10, 2004 | 12:36 PM
msghuff's Avatar
msghuff
I'll have to agree to this "lag" I had it in my 97 and 99 C5 I attributed it to the "Fly by wire" throttle body.
Old Sep 10, 2004 | 12:44 PM
birch64's Avatar
birch64
my 2000 c5 has it also...............
Old Sep 10, 2004 | 01:02 PM
bk97's Avatar
bk97
This may not apply to the Z06 lag problem, but it had it with my '97 C5. It went away when I replaced the stock filter lid with a Z06 lid. I have since went to the zip tie mod and it runs even better.
Old Sep 10, 2004 | 01:40 PM
ZO6vettepilot's Avatar
ZO6vettepilot
Originally Posted by GrantR
Hi guys,
Grant.
What gear are you in when this occurs?
zo6vettepilot
Old Sep 10, 2004 | 02:46 PM
freefall's Avatar
freefall
I've got an 02 z06, and it is independent of gear. An easy way to see this is when idling, jab the throttle - if you back off immediately, the blip is ignored. If not, I'd guess at .25-.5 second lag time before rpms increase.
Old Sep 10, 2004 | 05:38 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
No lag here... Instant power
Old Sep 10, 2004 | 06:19 PM
don527's Avatar
don527
if you turn off the active handling, does it still do it?
Old Sep 11, 2004 | 09:46 PM
C6~Missle's Avatar
C6~Missle
I was out today in my 04 Z and there is no noticeable lag. It is instant.
I get immediate response and the throttle plate is in sync with the accel pedal. I suggest you get yours checked as it might be binding or maybe you need a program change...
mike
Old Sep 12, 2004 | 03:01 AM
BigBlue's Avatar
BigBlue
Mine's almost to touchy. Blipping the throttle almost puts the engine at red line.
To Z06 throttle response lag
