P 0107 Code Please Help
Old Sep 10, 2004 | 10:18 PM
The Yav's Avatar
The Yav
Default P 0107 Code Please Help
Installed a new cam (21MC GT-9 228/588/114) did not take off the intake. Had the PCM reprogramed and occasionaly will throw a P 0107 Mat sensor low voltage. The check engine light comes on when I am in the higher RPMs is there a fix for this/has anyone had the same codes after installing bigger cam? Any info would be appreciated.
v/r
THEYAV
Old Sep 12, 2004 | 06:21 PM
The Yav's Avatar
The Yav
ttt
Old Sep 12, 2004 | 08:44 PM
Richin Chicago's Avatar
Richin Chicago
v/r
THEYAV
Don't have an answer but here is further info:
CIRCUIT DESCRIPTION
The Manifold Absolute Pressure (MAP) sensor is mounted to the rear of the intake manifold. The MAP sensor measures the pressure changes within the intake manifold which is an indication of the engine load. The MAP sensor has a 5.0 volt reference, a ground, and a signal circuit.
The MAP sensor contains a diaphragm which changes the sensors resistance based on pressure. When the manifold pressure is low (high vacuum) the sensor output voltage is low. When the manifold pressure is high (low vacuum) the sensor output voltage is high.
The MAP sensor voltage (depending on altitude) can range from 1.0-1.5 volts at idle (high vacuum) to 4.0-4.9 volts at wide open throttle (low vacuum). When the PCM senses a signal voltage lower than the normal operating range of the sensor, this DTC will set.
CONDITIONS FOR RUNNING THE DTC
No TP sensor DTCs set.
The engine is operating.
The TP sensor angle is 0 percent when engine speed is less than 1200 RPM . Or
The TP sensor angle is less than 20 percent when engine speed is greater than 1200 RPM .
CONDITIONS FOR SETTING THE DTC
The MAP is less than 0.10 volts .
All conditions met for greater than 4.0 seconds .
ACTION TAKEN WHEN THE DTC SETS
The PCM illuminates the Malfunction Indicator Lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the conditions to the Freeze Frame and updates the Failure Records.
CONDITIONS FOR CLEARING THE MIL/DTC
The PCM turns the Malfunction Indicator Lamp (MIL) OFF after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A last test failed (current DTC) clears when the diagnostic runs and does not fail.
A History DTC clears after 40 consecutive warm-up cycles, if this or any other emission related diagnostic does not report any failures.
Use a scan tool in order to clear the MIL/DTC.
DIAGNOSTIC AIDS :
IMPORTANT:
Remove any debris from the PCM/TAC module connector surfaces before servicing the PCM/TAC module. Inspect the PCM/TAC module connector gaskets when diagnosing/replacing the modules. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM/TAC modules.
For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616-A. Using this kit prevents damage to the harness/component terminals. Refer to Using Connector Test Adapters in Diagrams.
The PCM 5.0 volt reference circuits are internally connected within the PCM. If all the MAP sensor circuits are OK, inspect the Engine Oil Pressure sensor circuits for malfunctions.
For an intermittent, refer to Symptoms. See: Diagnostic Information and Procedures\Symptoms
TEST DESCRIPTION
The numbers below refer to the step numbers on the diagnostic table.
If DTC P1635 sets at the same time, this indicates that the 5 voltage reference circuit is either shorted to a ground or shorted to a voltage. The 5 volt reference circuit is internally connected within the PCM. The Engine Oil Pressure sensor circuits may be causing this DTC to set. Refer to DTC P1635 5 Volt Reference 1 Circuit for further diagnosis. See: P1635
This step determines if the malfunction is present.
Using the Freeze Frame and/or Failure Records data may aid in locating an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame and/or Failure Records data can help determine how many miles since the DTC set. The Fail Counter and Pass Counter can also help determine how many ignition cycles the diagnostic reported a pass and/or a fail. Operate the vehicle within the same freeze frame conditions (RPM, load, vehicle speed, temperature, etc.) that you observed. This will isolate when the DTC failed.
If the scan tool displays 5 volts , the MAP sensor signal circuit, 5 volt reference circuit, and the PCM are OK.
If the scan tool displays 5 volts , the MAP sensor signal circuit and the PCM are OK.
Disconnecting the PCM allows using the DMM in order to test the continuity of the circuits. This aids in locating an open or a shorted circuit
To P 0107 Code Please Help
