throwing a code
Old Sep 10, 2004 | 10:28 PM
Blow Torch's Avatar
Blow Torch
Default throwing a code
The vette has started throwing a P0161 code. Correct me if I'm wrong, but I believe that this is the code for the front O2 sensor.I have KOOKs headers that have been on for about 6 months, and have not had an issue. The confusing twist is that it does not throw it every time I drive. I have checked the wires and the do not appear to be burnt or kinked.
Anyone have any suggestions?
Old Sep 11, 2004 | 03:56 PM
Blow Torch's Avatar
Blow Torch
Anyone?
Old Sep 11, 2004 | 04:51 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
If the wires look good then the sensor may be getting ready to die for good
Old Sep 11, 2004 | 05:47 PM
HalfMoon's Avatar
HalfMoon
This is listed as "HO2S Heater Circuit Bank 2 Sensor 2". that's the Passenger side rear O2 Sensor.
Old Sep 12, 2004 | 10:50 AM
Blow Torch's Avatar
Blow Torch
Thanks guys;
The only problem now, is that not only have I removed the rear sensors (no cats) and replaced them with simms, but the tuner supposivly has programmed the PCM not to look at them???
Any thoughts on a possible cause?
Old Sep 12, 2004 | 12:41 PM
SERIOUS RACER's Avatar
SERIOUS RACER
ITS THE MASS AIRFLOW SENSOR IM HAVING IT LOOKED AT THIS WED WITH AN LS1 EDIT CONTACT ME WED FOR RESULTS GARY 1 631 888 1235
Old Sep 13, 2004 | 10:18 AM
HalfMoon's Avatar
HalfMoon
Thanks guys;
Have him remove that code. Sounds like he forgot to exclude that code when he removed the others regarding the rear O2s.
Old Sep 13, 2004 | 08:16 PM
Blow Torch's Avatar
Blow Torch
Thanks Tony
I've got to get the PCM reprogramed when I do my H/C. I'll get him to check it then
To throwing a code
