After bleeding the brakes, TCS C1247
If it is just an H it may be caused from you bleeding the brakes when the igntion is on. Clear the codes. If there is a C for current problem be very careful. You could have a system failure. How is the brake fluid level has it gone down from a leak? Is everything tight? How did you bleed the ABS unit?
Forn GM:
Circuit Description
The EBCM monitors the Brake Pressure Differential Switch to turn off Traction Control and Active Handling if a pressure loss is detected in the hydraulic brake system.
Conditions for Setting the DTC
DTC C1247 can be set anytime, if the EBCM detects the Brake Pressure Differential Switch has been grounded due to loss of brake pressure or a short to ground.
Action Taken When the DTC Sets
TCS/Active Handling are disabled.
Indicators that turn on:
RED Brake Warning indicator
Car Icon (TCS indicator)
Messages displayed on the DTC:
Service Traction System
Service Active HNDLG
Conditions for Clearing the DTC
Condition for DTC is no longer present and scan tool clear DTC function is used.
Fifty ignition cycles have passed with no DTCs detected.
Diagnostic Aids
DTC C1247 could be set during a hydraulic brake system bleeding procedure if the ignition switch is in the ON position.
It is very important that a thorough inspection of the wiring and connectors be performed. Failure to carefully and fully inspect wiring and connectors may result in misdiagnosis, causing part replacement with reappearance of the malfunction.
An intermittent malfunction can be caused by poor connections, broken insulation, or a wire that is broken inside the insulation.
If an intermittent malfunction exists refer to Intermittent and Poor Connections in Diagrams, Diagnostic Aids.
1. The ABS needs too be bled and that has to be done with a scan tool.
2. You have a leak somewhere.
That brake fluid that is now missing had to go somewhere and it either went to the ABS unit or it's leaking.
BTW - the air pump only runs for the first couple minutes of engine operation and then shuts off, so if you were driving down the freeway when the light came on, more than likely it's not because the air pump is disconnected
